pmackellow
Turbair Sprayer
All the pictures I have seen of various Turbair sprayers have the idle screw (with the spring missing) tightened all the way up jamming the governor as I mentioned before. I did question the missing spring when this latest one arrived, but it isn't used on the Turbair as far as I can tell.
*Note the following does not apply for the Turbair engine;
Normally the carb idle stop screw (fitted with a spring) is used to adjust the idling speed, the lower holes below that are used for a throttle cable (held with a clip) on tools/applications that use a remote throttle control, eg. the bike kit or outboard motor.
David
