the showman 4,074 #26 Posted May 28, 2016 I've ordered a 6 lt one, just waiting for it to arrive 1 Triumph66 reacted to this Share this post Link to post Share on other sites
sten 84 #27 Posted May 29, 2016 Something to think about before you buy one, I use mine mainly for cleaning a single carb but even though they have a built in heater it is a bit slow so I fill mine from the kettle, trouble is it needs 3 kettles full to cover the carb, not a big problem but frustrating when you just want to get it set up, so a smaller one would have probably suited me better, except when I put my bike carbs in it, not big enough for a bank of 4 carbs and you don't really want to be separating them. So ideally I need a smaller one and a bigger one but that's not going to happen. I still haven't tried carb cleaner, I just use washing up liquid. 1 Triumph66 reacted to this Share this post Link to post Share on other sites
the showman 4,074 #28 Posted May 29, 2016 Thanks for your input sten, ive been looking at them for a while and not used one yet. I didn't want to get a smaller one and find I cant get my carbs ect in it, although its 6 litres I think it holds about 5. its a learning curve for me so will update when it arrives and ive tried it out 1 Triumph66 reacted to this Share this post Link to post Share on other sites
Triumph66 1,256 #29 Posted May 29, 2016 I am looking to buy one myself but this is all new to me too....... Share this post Link to post Share on other sites
the showman 4,074 #30 Posted May 31, 2016 My cleaner arrived today not as big as i was expecting, its just right. its got a drain tap on the side which is handy, I've put my cup in the basket so you can see the size of it. glad I didn't order a smaller one will update you once I've had time to use it 6 Triumph66, nigel, HeadExam and 3 others reacted to this Share this post Link to post Share on other sites
pmackellow 2,728 #31 Posted May 31, 2016 That's a nice bit of kit Chris Share this post Link to post Share on other sites
nigel 1,874 #32 Posted May 31, 2016 That looks a nice bit of kit Share this post Link to post Share on other sites
Wristpin 399 #33 Posted May 31, 2016 On 29 May 2016 at 10:22 PM, sten said: Something to think about before you buy one, I use mine mainly for cleaning a single carb but even though they have a built in heater it is a bit slow so I fill mine from the kettle, trouble is it needs 3 kettles full to cover the carb, not a big problem but frustrating when you just want to get it set up, so a smaller one would have probably suited me better, except when I put my bike carbs in it, not big enough for a bank of 4 carbs and you don't really want to be separating them. So ideally I need a smaller one and a bigger one but that's not going to happen. I still haven't tried carb cleaner, I just use washing up liquid. Not sure of the validity of this but we were warned not to pre fill with water hotter than the machine's max temp as apparently filling with just boiled water can damage the bonding between the "vibrating thingys" and the bottom of the tank. Perhaps worth bearing in mind. 1 Triumph66 reacted to this Share this post Link to post Share on other sites
pmackellow 2,728 #34 Posted May 31, 2016 6 minutes ago, Wristpin said: Not sure of the validity of this but we were warned not to pre fill with water hotter than the machine's max temp as apparently filling with just boiled water can damage the bonding between the "vibrating thingys" and the bottom of the tank. Perhaps worth bearing in mind. The unit I use at work states that it is not advisable to fill the cleaner with per heated water, I would fill it cold and let it warm up personally... 1 Triumph66 reacted to this Share this post Link to post Share on other sites
pmackellow 2,728 #35 Posted May 31, 2016 Pre heated water even... 1 Triumph66 reacted to this Share this post Link to post Share on other sites
sten 84 #36 Posted May 31, 2016 27 minutes ago, Wristpin said: Not sure of the validity of this but we were warned not to pre fill with water hotter than the machine's max temp as apparently filling with just boiled water can damage the bonding between the "vibrating thingys" and the bottom of the tank. Perhaps worth bearing in mind. Thanks, I will have to be more patient and perhaps read the instructions more thoroughly. 1 Triumph66 reacted to this Share this post Link to post Share on other sites
Triumph66 1,256 #37 Posted May 31, 2016 This will be a learning curve for me when I get and use a ultrasonic cleaner. Any other tips worth mentioning to a novice? Share this post Link to post Share on other sites
pmackellow 2,728 #38 Posted May 31, 2016 Just now, Triumph66 said: This will be a learning curve for me when I get and use a ultrasonic cleaner. Any other tips worth mentioning to a novice? Not really other than what has been discussed already, they are a very useful item, and the price of Chris' one makes it very tempting !! 1 Triumph66 reacted to this Share this post Link to post Share on other sites
the showman 4,074 #39 Posted June 7, 2016 Had a play with the cleaner today, first I measured how much water it takes which was 8 pints i then took a pint out and added the metal cleaning liquid. the heater took an hour to get up to 70c i then put the parts in for cleaning and set the timer for 30 minutes. i wasn't sure what to expect and a couple of bits were well corroded and i thought i might be asking a lot but was quite suprized with the results. heres some photos of before and after 1 pmackellow reacted to this Share this post Link to post Share on other sites
pmackellow 2,728 #40 Posted June 8, 2016 Doing the job then Chris Share this post Link to post Share on other sites
Twinsport 29 #41 Posted August 4, 2016 Hi there, I have been using a 6 liter chinese ultrasonic cleaner for years now. Mostly carburettor cleaning due to the limited size. I tried all sorts of cleaning agents, but I have had most succes with a mixture of 10% toilet cleaner to 90% wind screen washer fluid (for brass cleaning) or 20% toilet cleaner to 80% wind screen washer fluid (for aluminum, zinc and steel cleaning). Don't use to much toilet cleaner! Brass will discolour and cheap aluminium (read: japanese carburettors) disappears if you go above 35% toilet cleaner. Both items are cheap, effective and easy to get. I usually run it at 45°C for 1 hour with toothbrush scrubbing at the end. A couple of examples can be seen here: It's parts that wasn't touched since 1945 and I think the pictures speak for themselves. I did paint the intake elbow though :-) /Steen 1 Triumph66 reacted to this Share this post Link to post Share on other sites
the showman 4,074 #42 Posted August 4, 2016 Thanks for the information, I'll give that a try. Share this post Link to post Share on other sites
Triumph66 1,256 #43 Posted August 4, 2016 That's a very useful tip and the photos speaks volumes as you say. Thanks Share this post Link to post Share on other sites
HeadExam 1,783 #44 Posted August 5, 2016 Wow, that does a great job. Truly a indispensable item Share this post Link to post Share on other sites
C-101plowerpower 548 #45 Posted August 5, 2016 wait, it also takes the rust off? i really need to get a big one then Share this post Link to post Share on other sites
Twinsport 29 #46 Posted August 5, 2016 Yep - the acid in the toilet cleaner also removes serface rust. It's nice, isn't it? :-) /Steen Share this post Link to post Share on other sites
C-101plowerpower 548 #47 Posted August 5, 2016 8 minutes ago, Twinsport said: Yep - the acid in the toilet cleaner also removes serface rust. It's nice, isn't it? :-) /Steen ah the acid, makes sence now. Share this post Link to post Share on other sites
Wristpin 399 #48 Posted August 5, 2016 Think that most points have been covered but what exactly is " caustic acid"? Share this post Link to post Share on other sites
nigel 1,874 #49 Posted August 5, 2016 I would think ether caustic soda or bleach I don't know of a toilet cleaner with acid in , you could burn your bum Share this post Link to post Share on other sites
Stormin 4,458 #50 Posted August 5, 2016 Toilet cleaner is for cleaning to toilet, Nigel. NOT you bum. Though I suppose it depends on the state of your bum. Share this post Link to post Share on other sites
