Wallfish 687 #1 Posted January 8, 2015 Not sure where this fuel tank came from but I was using it as an engine test stand before I found this engine. This tank had one of the air ports plugged so it can be used as a pressurized tank. The exhaust has a port on the manifold to pressurize the tank. The cover for the crank is copper pipe parts but appears to be made professionally. I put a 16 or 18 inch prop and spinner on it so it should really screw some air! Never did fire it up but I may get her going for this years upcoming engine shows, it would be fun to demonstrate it. Share this post Link to post Share on other sites
jparkes43 27 #2 Posted January 9, 2015 i say defiantly get he fired up and make a video of that as-well that is really cool james Share this post Link to post Share on other sites
Laserscottman 4 #3 Posted January 11, 2015 Yes,sir--that'll make a breeze for sure! It has a great carb that will respond a lot better than the original. I like the innovation for seealing the back of the crank too. Share this post Link to post Share on other sites
