moogie 372 #26 Posted October 24, 2015 Another part ticked off the list today, think its from a Fordson Dexta. The centre of the seat was completely rotten so had to be cut out and repaired. Still need to get a centre bolt and seat spring. 3 nigel, Stormin and Cub Cadet reacted to this Share this post Link to post Share on other sites
bankman 17 #27 Posted October 24, 2015 Looks like a Bedford gearbox, those four speed boxes were fitted right across the range of trucks etc from the fifties on. Pete. Share this post Link to post Share on other sites
moogie 372 #28 Posted November 13, 2015 (edited) Got my front hubs today, very happy with how they turned out. Total cost of all parts and machine work £60. Now that i can measure the width of the front axle i can make a start on narrowing the rear axle. The Vitara axle has a offset diff so i need to remove 280mm from one axle tube and 320mm from the other. Once cut i will add a sleve to strengthen the tube and the half shafts will be sent out to be shortened. Need to go now and get a lend of a slide hammer to get the half shafts out and then the cutting can begin. Edited November 13, 2015 by moogie 8 wurzel, Vinnetrow, Alan and 5 others reacted to this Share this post Link to post Share on other sites
Ian 2,417 #29 Posted November 14, 2015 The hubs look good, a good "all in" price as well.. I'm looking forward to seeing the axle narrowing.. Plenty of photos please Share this post Link to post Share on other sites
diggerjames 543 #30 Posted November 22, 2015 I'm watching this build with interest looking good so far ! 1 wurzel reacted to this Share this post Link to post Share on other sites
moogie 372 #31 Posted April 28, 2017 Finally getting back to this project. Spent the day cutting down the axle tubes. Sorry, forgot to take photo's. I was able to cut the hub off the tube, shorten the axle and then sweat the hub back on again. It still needs to be fully welded also. Half shafts are going to be sent to my local machine shop to be shortened. They will be cut and then machined mortice and tennon style, sweated together and then a sleve welded over the joint. 3 Alan, Cub Cadet and Stormin reacted to this Share this post Link to post Share on other sites
