moogie 372 #1 Posted March 16, 2016 Does anyone have any tips on a handy way to clean rust and corrision off the cooling fins without disassembling the engine and having it blasted. Thanks, Noel. Share this post Link to post Share on other sites
Stormin 4,458 #2 Posted March 16, 2016 I use a small wire brush, emery paper, wire wool and a stick. 2 Cub Cadet and S1g reacted to this Share this post Link to post Share on other sites
expeatfarmer 591 #3 Posted March 16, 2016 I use a long thin grindstone on a Dremel and flappy sanding wheels. 1 S1g reacted to this Share this post Link to post Share on other sites
Wristpin 399 #4 Posted March 16, 2016 In the absence of a Dremel, a length of wooden dowl or steel rod with a slot in the end. Thread a bit of the appropriate grit emery cloth through the slot and run at moderate speed in the drill. 2 Ian and S1g reacted to this Share this post Link to post Share on other sites
