Potash123
Mountfield HP 414 Domestic mower
Had this little mower a couple of years, it's been good. Today I primed it and it started straight away, it cut out after a few seconds. This happened several times. Main jet blocked I am thinking, starting on the primer then running out of fuel !
I just stripped the cab and cleaned it out, carb cleaner, fuse wire etc. Now it starts and runs, but the revs are going up and down caused by movement of the governor arm. It will not settle even by adjustment of the throttle stop, Is there a pilot
jet I have missed. Help please.
Is it the Briggs and Stratton engine with the carb on top of the fuel tank
these can suffer with diaphragms           perishing and I've known the plastic carbs to come loose on the tanks causing     hunting as you describe
check the carb is tight to the tank
check air filter is clean
check mixture adjustment
failing that fit a carb rebuild kit
Well found the problem which I thought I would share it with everyone. Pampas leafs had wrapped itself round the drive shaft above the blade. It was so tight it acted like a brake causing engine issues. Took ten minutes to unwrap the leaves. Now running fine.
