bubbalove 54 #1 Posted February 10, 2017 hi chaps wondered if you could help me w/h c161 16 hp kohler with the engine running and the pto clutch engaged what would the rpm of the drive pulley be lets say half revs im trying to work out the pulley size if i was to run a hydraulic pump at say 3000 rpm Share this post Link to post Share on other sites
C-101plowerpower 548 #2 Posted February 10, 2017 8 minutes ago, bubbalove said: hi chaps wondered if you could help me w/h c161 16 hp kohler with the engine running and the pto clutch engaged what would the rpm of the drive pulley be lets say half revs im trying to work out the pulley size if i was to run a hydraulic pump at say 3000 rpm rpm of the drive pulley is the same as that of the engine, so you'll have to work of the diameter of the pulley. theres plenty of those calculators on the net Share this post Link to post Share on other sites
bubbalove 54 #3 Posted February 10, 2017 am i right in thinking when engine revs flat out it should be going 3600 rpm ??? Share this post Link to post Share on other sites
C-101plowerpower 548 #4 Posted February 10, 2017 Just now, bubbalove said: am i right in thinking when engine revs flat out it should be going 3600 rpm ??? if the governer is set right is should be Share this post Link to post Share on other sites
bubbalove 54 #5 Posted February 10, 2017 thanks mate Share this post Link to post Share on other sites
meadowfield 1,900 #6 Posted February 11, 2017 K341 and magnum 16 are usually set to 3000rpm governed speed. same size pulley on engine and pump will give you 3000rpm tops. Share this post Link to post Share on other sites
Anglo Traction 997 #7 Posted February 11, 2017 Mmm, My manual states it runs at 3600 which is max for a standard motor (except K91). Therefore 1800rpm at half throttle. Not recommended to run constant below normal full rpm for various reasons (e.g. Oil splash Lubrication, Alternator output and HP). Suspect it would be best to set your pump to run at it's normal rpm when the engine is at or near full speed (I set my engines to 3450rpm using a cheap Laser Tacho). Share this post Link to post Share on other sites
meadowfield 1,900 #8 Posted February 11, 2017 Hmm, my magnum 16 has a sticker saying 3000 is the max speed. I just assumed that was due to its size? Share this post Link to post Share on other sites
Wallfish 687 #9 Posted February 12, 2017 18 hours ago, meadowfield said: Hmm, my magnum 16 has a sticker saying 3000 is the max speed. I just assumed that was due to its size? We Americans just want you guys to have slower machines than ours so we put those 3000 rpm stickers on all the international engines. Curious if that engine is original to a tractor or if was spec'd for a different type of machine? Pretty darn sure all of mine are spec'd for 3600 rpm. On 2/10/2017 at 3:44 AM, bubbalove said: hi chaps wondered if you could help me w/h c161 16 hp kohler with the engine running and the pto clutch engaged what would the rpm of the drive pulley be lets say half revs im trying to work out the pulley size if i was to run a hydraulic pump at say 3000 rpm I'm with Richard on this. Not sure why you would want to load that engine at half rpm since those engines are designed to run at full rpm for cooling, lubrication and performance. Why not just run it at full rpm? For calculating pulley size, there are many online calculators to use, as stated above. Very handy for exactly what you're doing. Share this post Link to post Share on other sites
bubbalove 54 #10 Posted February 13, 2017 thanks chaps only reason i said 3000rpm is if ive got my calculations right at 3000rpm i will defiantly be running the pump at a higher rpm full revs Share this post Link to post Share on other sites
