Dicky mint
Horwool 84 triple x
Hi all
New member here.
I have just bought a pair of Horwool Triple X 84's to hopefully do up and get running. the only problem being that i do not have a clue what i am doing.
I bought them for nostalgic reasons as my Grandad had one when i was younger.
Any tips on where to begin, where to get parts etc is much appreciated!
Cheers
Iv just finished mine.
These later became known as nicholson turfmaster.
Iv not come across a a place to buy parts... I was lucky to.have most bits with mine.
I done a full strip down and rebuild with some changes i.e larger rear wheels.
Best I can take at minute will empty garage soon and get some proper snaps. One appears in reasonable condition but has been stood a long time the other not as good! Hoping between the two I will get one looking top notch. Both have split tires so moving them is hard work
Looking good. Best thing would be get then out in the sunshine and start tinkering.
Download engine manuals and get them running then work your way through them.
The rear brake set up.is the same as.morris minor
Thanks everyone I have printed out the engine manual. One has a external coil not sure on wiring to it though as all unattached when we got it. Will drag them out and get some fresh fuel and oil in them.
There's some wiring info in Matt's Horwool engine woes thread. As you strip them, take plenty of photo's for reference on re-assembly.
As a point of interest, where about in Lancashire are you? I'm originally Lancashire born and bred.
