the showman 4,074 #1 Posted December 31, 2017 Now the disruption of Christmas is over its back to the shed. This is a Raider 10 thats been in the back of my woodstore for a few years and during my rebuild on the Raider 12 ive been piling bits together to put it together. Had a bit of a late start as i had to clear all the sawdust after sawing up a load of wood during the last couple of days. This is as far as ive got today apart from the chassis is now sanded down to bare metal 8 Alan, Cub Cadet, nigel and 5 others reacted to this Share this post Link to post Share on other sites
the showman 4,074 #2 Posted January 2, 2018 Managed to get in the shed and do a bit more. i finished getting the rust and crap off the chassis and got a coat of primer on it and sorted out a couple of attach a matic thingys. 8 Ian, Cub Cadet, Stormin and 5 others reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #3 Posted January 2, 2018 Couple of weeks and you'll have rebuilt and running. 1 ACman reacted to this Share this post Link to post Share on other sites
the showman 4,074 #4 Posted January 7, 2018 Got a few more bits sanded down and primered 7 ACman, Ian, pmackellow and 4 others reacted to this Share this post Link to post Share on other sites
the showman 4,074 #5 Posted January 12, 2018 I had to leave this for a few days as i had other commitments namely mot on the Sprinter and the Chevy . Im sorting out the transmission that seems to be weeping oil and the hitch pin is rusted solid which will need drilling out. I pulled another box out but thought I'd carry on with the original. I had to leave it over night to let whatever was in it to dribble out, it certainly wasn't sae 140. I cut through the pin each side to remove the hitch and spacers the cut it again near the casing, drilled a hole through the pin using 3 different sizes drill bits then nocked it out. Ive ordered some new axle seals from Toro and think i have the others in stock. Next job will be to remove all the pulleys and hubs and clean it up. Heres some photos of today's activities. 5 Cub Cadet, Stormin, ACman and 2 others reacted to this Share this post Link to post Share on other sites
ACman 15 #6 Posted January 12, 2018 Nice work Chris. I sure do miss wrenching on tractors , but I’m glad that I can still enjoy watching others. 2 the showman and Stormin reacted to this Share this post Link to post Share on other sites
the showman 4,074 #7 Posted January 13, 2018 Today's progress has been a bit slow due to a very stubborn hub, i warmed it up and bolted a puller on but no joy. I gave it a good soaking and tried again still wouldn't move. Next I connected up the gas axe to get more heat and quicker, with it glowing it still refused to move so i went for a cuppa to cool off. I thought I'd give it one more chance if not I decided to leave it rather than brake it. Same again with loads of heat and an extension pipe on my T bar it moved and off it came, next was the other side so with puller fitted it slid straight off. It was a lot of work but at least i got them off and can change the oil seals and I didn't break anything. 8 4x4forks, nigel, Stormin and 5 others reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #8 Posted January 13, 2018 Sometimes heating then letting cool, helps to break the seal. Then heating again finishes the job off. Well done. 1 the showman reacted to this Share this post Link to post Share on other sites
Wristpin 399 #9 Posted January 13, 2018 May sound a bit brutal but supporting the boss on a substantial lump of iron such as an anvil or a bit of RSJ / angle iron and hitting the opposite side with a substantial drift and a large lump hammer, rotating the boss as you go, will cause enough "shock stress" free it. Also works well for taper fits. Share this post Link to post Share on other sites
the showman 4,074 #10 Posted January 14, 2018 The last thing I wanted to use was a hammer Angus, ive got a feeling the hubs are cast as ive seen a few of them broken across the lug nuts holes. Also you can't give the boss a tap because it pings the circlip off the axle inside the diff then you have to strip the box to put it back on. Share this post Link to post Share on other sites
Stormin 4,458 #11 Posted January 14, 2018 The hubs are cast and very easily broken. I've one off the Raider 10 with a chunk out. Not down to me I hasten to add. Share this post Link to post Share on other sites
Wristpin 399 #12 Posted January 14, 2018 1 hour ago, Stormin said: The hubs are cast and very easily broken. I've one off the Raider 10 with a chunk out. Not down to me I hasten to add. Ah, didn’t realise that they were cast, quite agree. However, if they were safe to hit, no danger of “ pinging” the circling as the impact is at right angles not logitudanly . Share this post Link to post Share on other sites
the showman 4,074 #13 Posted January 15, 2018 Got a bit more done to the transmission today dodging the showers. I powerwashed the degreaser and crap off then used the drill with a wire brush and a paint stripping pad to clean off the paint and rust finally giving it a coat of primer. Had a phone call to say the oil seals are on their way. Woof Woof. 2 Alan and Stormin reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #14 Posted January 15, 2018 You realise if you paint the trans', you have to paint all the rest. Share this post Link to post Share on other sites
the showman 4,074 #15 Posted January 16, 2018 On 15 January 2018 at 7:49 PM, Stormin said: You realise if you paint the trans', you have to paint all the rest. I was hoping not to get that involved with this but it's looking that way, I'll wait till ive got it painted and see how clean the hood and rear fender come up. Share this post Link to post Share on other sites
the showman 4,074 #16 Posted January 17, 2018 4 Ian, Alan, Cub Cadet and 1 other reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #17 Posted January 17, 2018 That looks better. Share this post Link to post Share on other sites
Ian 2,417 #18 Posted January 17, 2018 Looks like you having fun with the build mate, good work getting the hubs off, I hate having to cut them off! Share this post Link to post Share on other sites
the showman 4,074 #19 Posted January 18, 2018 Still waiting for the oil seals to turn up so only a small update, just a few more bits primered. 4 Stormin, Ian, Alan and 1 other reacted to this Share this post Link to post Share on other sites
the showman 4,074 #20 Posted April 2, 2018 Had some time today and as the weather was crap i thought I'd have an hour in the shed. First job was to clean the axles and shafts and remove the old oil seals, this was done by piercing the seal with a pointed tool then pull it out with a hook tool. i needed something to push the new seals in and used a short bit of water pipe and a piece of tube from a trampoline frame that just happened to be an exact fit, i put a bit of tape over the keyway slot so the new seal wouldn't snag up or get damaged. I used some rubber lubricant and they went in really easy. 5 nigel, Cub Cadet, Stormin and 2 others reacted to this Share this post Link to post Share on other sites
nigel 1,874 #21 Posted April 2, 2018 Hayter seals ? Share this post Link to post Share on other sites
the showman 4,074 #22 Posted April 2, 2018 5 minutes ago, nigel said: Hayter seals ? Yes that's what was suppied 1 Cub Cadet reacted to this Share this post Link to post Share on other sites
Wristpin 399 #23 Posted April 2, 2018 4 hours ago, nigel said: Hayter seals ? Toro now owns Hayter so are "rationalising" the parts bin. 2 Ian and nigel reacted to this Share this post Link to post Share on other sites
Ian 2,417 #24 Posted April 25, 2018 On 02/04/2018 at 11:32 PM, Wristpin said: Toro now owns Hayter so are "rationalising" the parts bin. That's handy to know should I need to get new gearbox seals Nice work Chris, the speed your going your have the Raider finished in a month or so Share this post Link to post Share on other sites
the showman 4,074 #25 Posted November 18, 2018 Here's a reminder Norm for the axle seals 1 Triumph66 reacted to this Share this post Link to post Share on other sites
