Scottwilson
Hand brake help
3 minutes ago, the showman said:
It clips in when you push the brake pedal down
That’s what I thought but it won’t clip in when the pedal is pushed down .
1 minute ago, the showman said:
If you sit on the tractor and hold the brake pedal down and pull the lever it will hold the brake on then press the pedal and it will release it
Maybe it’s bent then as when I press the pedal it don’t come back far enough. I’ll have another look tomorrow
