Steve2018 3 #1 Posted July 11, 2018 Hi, im trying to remove the main engine pulley shaft as its broken but I cant get it off, its been on for 25 odd years so seems stuck in place. I have the engine out but just cant get it off :-( any tips? I could cut it off but wanted to try and save it if possible to take to a fabricator to see if it could be welded back together. My other idea if i cant get it off was this that i drew while at work do you think this will work? Or instead of that bolt going through the side, a better idea maybe is to get a longer main shaft bolt and washer to hold it all together? Forgot to mention the pipe i have to slot in is a nice tight fit Share this post Link to post Share on other sites
the showman 4,074 #2 Posted July 11, 2018 What engine is it Steve, ? Share this post Link to post Share on other sites
Steve2018 3 #3 Posted July 11, 2018 Hi, its a Lawnflite 504 with a briggs and stratton 8hp engine Thanks Share this post Link to post Share on other sites
Stormin 4,458 #4 Posted July 11, 2018 Can you post a photo? We will see the problem better. Share this post Link to post Share on other sites
the showman 4,074 #5 Posted July 11, 2018 Have you removed the bolt up inside the tube of the pulley, think its 9/16 AF or 5/8 AF Share this post Link to post Share on other sites
Steve2018 3 #6 Posted July 12, 2018 Yea i removed that bolt, tried a puller on it but it just seems to bend the pulley thats still attached. Heres a pic thanks Share this post Link to post Share on other sites
Stormin 4,458 #7 Posted July 12, 2018 You could try turning the engine upside down and pouring diesel or hydraulic oil down the tube. You'll need to leave it like that for a week or two to allow the fluid to work it's way through. Heat is another option but you could damage the shaft seal. Share this post Link to post Share on other sites
meadowfield 1,900 #8 Posted July 12, 2018 weld a nut into the broken shaft and screw a bolt in and then it will just wind the existing pulley off. I've never seen on seized as they rarely see any moisture - only oil! good luck 1 Anglo Traction reacted to this Share this post Link to post Share on other sites
Anglo Traction 997 #9 Posted July 12, 2018 Would be handy to establish if the Engine output shaft/Pulley unit has a parallel shaft, or tapered, with a Keyway. Certainly Mark's suggestion will add the advantage of some heat to create a difference between the 2 components, to improve separation. Share this post Link to post Share on other sites
meadowfield 1,900 #10 Posted July 12, 2018 of the dozen or so Briggs verticals I have worked on they are all 1" straight shaft with an inch long key (not half moon) The flywheel end on the other hand is always a 1" tapered with short very soft key that is designed to shear when things go wrong (don't ask how I know) Share this post Link to post Share on other sites
HeadExam 1,783 #11 Posted July 12, 2018 I've used two oak wedges between the case and pulley and driven them off when the pulley failed to do so. Share this post Link to post Share on other sites
Wristpin 399 #12 Posted July 12, 2018 (edited) It is a parallel shaft with a straight key. Get two pieces of "tin" and cut a U shaped slot in both and slide them in between the sump and the pulley from opposite sides to protect the sump. In these circumstances the seal is expendable! Find a friendly mechanic with oxy-acetylene and get the pulley and its sleeve cherry red, leave it to cool and then give it the diesel soak treatment. It will then probably lever off with a couple of tyre levers or pry bars. Protect the sump further with some scrap steel under the heels or fulcrums of the bars. Or use folding / fox wedges as suggested by Headexam. Perhaps someone knows why they are called Fox wedges? Edited July 12, 2018 by Wristpin Share this post Link to post Share on other sites
