HeadExam 1,783 #1 Posted September 1, 2018 My 1969 Bolens 1476 Hydrostatic with the 14 hp S-14D Wisconsin has a 48" shaft drive deck that I can mow the cow pasture and not have any issues, three foot grass isn't a problem, I have 27"x 9.50"- 15" Duro Frontier All Terrain tires on the back and original Goodyear 5.30-8 tires on the front. The hydro unit holds 11 quarts of transmission fluid inside a solid cast iron rear end and trans axle and weighs a little over 1,000 ponds without a deck or implements; I have two of these. My 1973 Allis Chalmers 416 Shuttle has 48" belt drive right hand discharge deck and a 16 hp single cylinder cast iron Kohler K341 engine mated to a 4 speed Hydro, Yep, 1st, 2nd, 3rd, and 4th gear is both infinite forward and reverse. Rear tires are 25"x 10"-12" Carlisle All Trails with 25 pounds of weights on each wheel with 4" axle extenders to give it a real wide track or you can remove them and install them on the outside to mount a set of dual wheels, Fronts are smooth ribbed 16x6.50-8 for easy turn and easy on the turf. This machine was only built one year and I have two other A/C 416s true Hydro units as well. These are the two machines I use to mow this year, next year I will charge two more for mowing duties. This keeps them up and running, but not overburdened. 7 Scottwilson, Triumph66, Fix'em all and 4 others reacted to this Share this post Link to post Share on other sites
Triumph66 1,256 #2 Posted September 1, 2018 Two great looking machines you got there Alain. Well jealous ! 1 HeadExam reacted to this Share this post Link to post Share on other sites
