callander ploo-man
Here is my winter project
It's an Atco with an Aspera engine. The machine was available in both 18 and 21" widths of cut . Yours looks to be 18" . I have illustrated parts lists and owners' manuals.
Check for fuel leaks around where the tank brackets are spot welded to the tank. They tended to develop vibration related stress cracks around the spot welds. Easy cure was to seam braze right round the bracket.
Quote
If you need Aspera parts you may be best searching for Tecumseh.
Although the Italian made Aspera was made under licence from Tecumseh there were differences so due intelligence is required when cross referencing!
Does that mean there will be both metric and imperial fixings as well?. I haven't done a LAV example.
