Cub Cadet 611 #51 Posted December 11, 2018 Great work Norm! 1 Stormin reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #53 Posted December 12, 2018 Three coats of primer and red top coat applied to the bonnet today. Also the drive belt guard. Flywheel cover and a couple of engine covers primed also. Hope to get the black done tomorrow. 4 Anglo Traction, nigel, HeadExam and 1 other reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #54 Posted December 13, 2018 I got the bonnet masked up and one top coat on today. But it was to cold really for painting. -2c with the east wind. So I got the engine onto the bench and started to remove what I needed to, prior to removing the piston and rod. I'll take those out tomorrow and give it a clean, then see about getting the bore, which looks good, deglazed. 2 HeadExam and nigel reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #57 Posted December 18, 2018 Checked the bore today and it is within spec. So after a deglaze, the new piston, rings and rod got fitted. The engine is now complete but before I refit it, it'll get painted. There are still some bits and bobs to paint and the bonnet to finish, but the weather is too wet and damp for any more painting. 2 expeatfarmer and HeadExam reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #58 Posted December 20, 2018 Managed to get quite a bit done today. One or two hiccups, but a good day. Got the engine painted this morning and the paint dried quite quickly. By lunch time it was back in place. Next I fitted the drive belt and this was when I hit problem number one. As you can see in the photo', the bottom run is under the brake pedal. Should be over the top. So foot plate had to be loosened, the pedal moved out and the operating rod disconnected from the pedal. Got that correct and moved on to the P.T.O. This provided a little snag, as the support bar would not connect to the pulley spindle. Cured that by taking everything off again and moving the drive pulley further in. It wasn't quite fully on by about 1/16". Just enough to prevent support bar connecting with the shaft. All OK now. Fuel pump is now refitted along with governor linkage. Finally I thought it a good idea to fill the engine with oil, which I duly did. After which I did a bit of tidying up before returning to the tractor. Then I SAW IT. A big puddle of oil under the tractor. The C-125 has a tube attached to where the drain plug would be. I'd forgotten to fit it. 4 Alan, slf-uk, Cub Cadet and 1 other reacted to this Share this post Link to post Share on other sites
Cub Cadet 611 #61 Posted December 21, 2018 On 12/11/2018 at 5:05 PM, Stormin said: I'll be wanting the graphics soon. See what you dad's got in stock. Lets us know, we'll have to print them, will give you a good deal 1 Stormin reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #64 Posted December 24, 2018 First photo' is where the crack is. As you can see it's barely visible. You can't see it with naked eye. So I have this metal repair epoxy adhesive which I've used before with success on a petrol tank. Below is it applied. The sump is now on the bench and filled with oil. I'll leave it there for a couple of days. 4 HeadExam, Cub Cadet, slf-uk and 1 other reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #69 Posted December 26, 2018 Got a bit more done today. Engine back on and engine covers fitted, along with the recon carb off Anglo Traction. I have found there's still a slight trace of a leak from the sump. So I think I'll have to find a replacement. 2 Cub Cadet and HeadExam reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #70 Posted December 27, 2018 Got the wiring done today. Found a couple of dodgy connections but everything works ok. Put a battery on, some petrol in and with a bit of persuading it started up. Played about adjusting the carb and got it running something like. Had to take the fuel pump off as it had a bit of a leak. Re-sealed it and that's sorted. Had a spare spring I couldn't think where it belonged. Turned out it was off the P.T.O. lever. So that's back on where it belongs. At one point I knelt on the floor and something stuck me in the knee. Turned out to be a front wheel nut. Silly me hadn't tightened them up. They're tight now and the rear ones checked. They were ok. The leak from the sump is barely discernible. No drips. Should be fine till I source a replacement pan. So nearly there. 2 Alan and HeadExam reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #71 Posted February 4, 2019 Just in case anyone is wondering, progress came to a halt after Christmas, due too a refurbishment of the kitchen. This meant the workshop became a storage/assembly shop. And as stuff went into the house, things came out and into the workshop. Hopefully all will change, in the workshop at least, this weekend and I can get back to the tractor and normality. 3 Cub Cadet, Alan and slf-uk reacted to this Share this post Link to post Share on other sites
Alan 1,271 #73 Posted February 9, 2019 3 hours ago, Stormin said: Took time off from working on the kitchen and got into the workshop. Got the 125 from the corner where it's been sitting to wire up the lights and one or two other bits. Lifted the bonnet and where the fingers locate the metal work gave way. Front of bonnet hit the floor. So bonnet is now on the bench. I'll make a re-enforcing plate for it. And of course some paint work to repair. Another excuse to get out of the kitchen. "Carol, I just need to finish this urgent job first". 1 Stormin reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #74 Posted February 10, 2019 Got another day in the workshop. Sorted and replaced the bonnet. All that's left now are the tach-o-matics to paint and fit. Touch up some bits of paint work and order graphics. Another exhaust will be made later. May not be a stack though. That's it. Horse ready to be put back into harness. 6 Alan, expeatfarmer, nigel and 3 others reacted to this Share this post Link to post Share on other sites
Cub Cadet 611 #75 Posted February 26, 2019 Looking awesome Norm! Really like the narrow wheels on the front of the C-series, best thing I did to my C-121. 1 1 Stormin and HeadExam reacted to this Share this post Link to post Share on other sites
