CNew
O&R Tools: One-By-One Mini Water Pump and Sno-Tiger?
Curious if anyone has, or has ever seen, the little O&R water pump called the One-By-One made by Lancaster or the Sno-Tiger (not sure who made it) which looks to be some sort of mini snow blower.
Lancaster pumps are still in business, they did sell chainsaws with O&R engines but I've not yet seen a pump using one.
Some history of Lancaster here, apparently C-B Tool Co were the manufacturer for Lancaster and they bought them out in 1978.
http://vintagechainsawcollection.blogspot.com/2008/11/partner-c6-sweden.html
Orline (O&R) made the Sno-Tiger, we haven't found a survivor yet, possibly because they are fairly large and the casing is supposedly made from plastic, I imagine they were probably all thrown out when the engine stopped working or the plastic fell apart.
David
I bet you’re right, between the flimsy frame and all the plastic shrouds they probably didn’t fair well.  Would be fun to see a picture of a real one though...
22 hours ago, mattblack said:
That axle/handle set up doesn't look too substantial, I bet rust claimed a lot if they were put away wet.
That's certainly possible, I've also had a thought that the plastic housing could be easily damaged if it ingested anything more solid than snow (i.e. stones).
David
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
