857 10 #1 Posted July 6, 2019 Hi Folk, Me again, what number spark plug do you use on your K181 engine. I have searched the service manual and can only find the Kohler part number! I am still having problems with it, a bit of smoke I may have to have a rebore. Anyone going to Wiston next weekend, perhaps I could have a chat with? Thanks Terry 1 Triumph66 reacted to this Share this post Link to post Share on other sites
squonk 71 #2 Posted July 7, 2019 If I remember right I use Autolite 458 Share this post Link to post Share on other sites
Anglo Traction 998 #3 Posted July 7, 2019 Manual reccommends Champion RCJ8 0.025" gap (unless running on propane etc). Not sure if modern ones are as good as the old ones, so here is a cross reference for loads of alternatives grabbed from the net- Share this post Link to post Share on other sites
857 10 #4 Posted July 8, 2019 Many Thanks for your replies. Share this post Link to post Share on other sites
ol' Grump 8 #5 Posted July 12, 2019 In most of my gas engine I use Autolite plugs, but in the chainsaw NGK or Bosch seem to work better. Champion plugs don't seem to be the same quality as they were years ago Share this post Link to post Share on other sites
Stormin 4,458 #6 Posted July 12, 2019 As to the bit of smoke. Does it use much oil? After a couple of hours running, My C-125 needed an oil top up. A deglaze and new rings and now it uses none. Share this post Link to post Share on other sites
nigel 1,874 #7 Posted July 12, 2019 I prefer nvm plugs Share this post Link to post Share on other sites
857 10 #8 Posted July 16, 2019 Stormin Thanks for your reply I didnt get back sooner been away at a steam rally only just got home. I did used a new set of ring from Cox & Turner with the scraper ring being a one piece as apposed to the three split type I thought they were gapped correctly but I am now thinking that is where my problem is. This weekend I had to top up the oil by 300 ml didnt smoke much only on start up, comlete strip down now, and start again. Thanks Terry Share this post Link to post Share on other sites
Stormin 4,458 #9 Posted July 16, 2019 Just make sure, if you don't know, to stagger the ring gaps. When I removed the piston from my C-125, I found the gaps were in line. It may not have needed new rings. Share this post Link to post Share on other sites
Wristpin 399 #10 Posted July 17, 2019 21 hours ago, Stormin said: Just make sure, if you don't know, to stagger the ring gaps. When I removed the piston from my C-125, I found the gaps were in line. It may not have needed new rings. It’s certainly good practice to stagger ring gaps when assembling an engine; wherever possible I try to avoid having a gap on the thrust side of the piston. It’s generally accepted that rings rotate during use, known I believe as cyclic rotation, so all the gaps ending up in line is strange indeed. Share this post Link to post Share on other sites
857 10 #11 Posted July 24, 2019 Curiosity got the better of me I couldn’t wait until the winter, now stripped the engine down and could find only one possible problem causing excessive oil consumption, it used 300ml in 2/3 hours use, and the oil ring gap was only about 20 degree away from the middle ring gap and should have been 120 degree a third apart, do you thing the close proximity could be the problem? The manual quotes a maximum of .027 ring gap I have less than .015 on all the new rings. All other measurements are within manual specifications. Terry Share this post Link to post Share on other sites
ol' Grump 8 #12 Posted July 24, 2019 With the older Cat diesel engines, sometimes to help "break 'em in" a small teaspoon of Bon Ami cleaner was slowly fed into the air intake. In a Honda portable generator that was burning oil after an overhaul I used the Bon Ami treatment, but less than half a teaspoon very slowly fed in after I'd taken the air filter off. That seemed to cure the problem. Just an idea Share this post Link to post Share on other sites
Wristpin 399 #13 Posted July 24, 2019 8 hours ago, 857 said: Curiosity got the better of me I couldn’t wait until the winter, now stripped the engine down and could find only one possible problem causing excessive oil consumption, it used 300ml in 2/3 hours use, and the oil ring gap was only about 20 degree away from the middle ring gap and should have been 120 degree a third apart, do you thing the close proximity could be the problem? The manual quotes a maximum of .027 ring gap I have less than .015 on all the new rings. All other measurements are within manual specifications. Terry As far as I can see, you dont mention glaze busting / honing the bore before fitting the new rings. If that has not been done it is almost certainly the cause of the higher than expected oil consumption. Also, did you check that the cylinder dimensions were within spec for re-ringing - both diameter and out of round ? It would be normal practice to check those measurments at three positions covered by the piston movement in the bore - top middle and bottom. They would be the deciding factor when considering whether the engine is suitable for re-ringing or is in need of a rebore.. Finally, I know that for some engines Kohler do a "service ring set" specifically to take up wear within the prescribed limitations. Also, the Cords piston ring company can supply special ring sets for worn engines and I see that they list sets for Kohlers.. Share this post Link to post Share on other sites
857 10 #14 Posted July 24, 2019 Yes I did hone the bore but maybe not enough. I decided to phone a rebore company of 35 years experience in high performance motor bike engines and I can see them tomorrow, they are prepared to check the engine over including measurements while I wait, I may have something to report back tomorrow. Thanks for all your comments. Terry Share this post Link to post Share on other sites
Anglo Traction 998 #15 Posted July 25, 2019 There are several possible reasons for excessive oil consumption in these older 'K' engines, so I'm not sure if you have covered all of them off yet?. Use of correct Oil. It is often experienced that use of modern synthetic blends etc in these engines can cause high consumption. They were designed for Mineral based Oils. A good 30 wt oil of spec as specified in the manual for air cooled, splash lubrication will always serve well. It is also possible that fitting new rings to a worn/used bore will not improve it's current condition very much. It may be worn 'out of round' , of which there is a limit quoted. As mentioned, deglazing a cylinder can work wonders for a tired engine, but it needs to be done correctly to resemble the finish of a newly honed engine. Kohler recommend the honing marks should intersect at approx 30degrees, and if these marks are either too steep or shallow, the oil consumption/friction can increase. Here is an example of the correct honing finish (after a rebore)- There is another area to check, if not already done so. The valve guides are a possible cause and can have the same affect as worn rings on Oil use and by causing the crankcase to be pressurised, instead of running with a partial vacuum. These are good engines and are readily able to be rebuilt, so I for one am pleased with your clear determination to get this one back up to spec. I hope your potential engine rebore service is local to you. It's a few years since I had a K301 fully worked by Sutton Rebore Services and I was so impressed by their standards and prices. The sound of an almost 'back to new' engine running as it should is payment enough. Regards 1 Stormin reacted to this Share this post Link to post Share on other sites
Wristpin 399 #16 Posted July 25, 2019 Quote. "The valve guides are a possible cause and can have the same affect as worn rings on Oil use and by causing the crankcase to be pressurised, instead of running with a partial vacuum." Also, it's as well to check the operation of the crankcase breather valve which is incorporated into the valve chest cover. Its correct operation is essential for maintaining negative pressure in the crankcase to assist in keeping it oil tight. Share this post Link to post Share on other sites
