Rayp
McCulloch/Paretner Wheeled Weed Trimmer
The belt broke on my wheeled trimmer and having replaced it I am struggling to locate the location for the ends of the return spring (part no. 15 on the attached parts diagram).  Can anyone help please?
ON THIS TRIMMER DO YOU HAVE A HANDLE TO ENGAGE THE HEAD ?
IF SO THE SPRING HAS TO DISENGAGE THE BELT SO IT NEED TO PULL  THE IDLERS BACK AWAY FROM THE BELT.
NOT SURE WARE THAT SPRING HOOKS . BUT IT HAS TO PULL BACK TO TO RELEASE THE PRESSURE FROM THE BELT
 Yes the handle does have a lever to engage the head.  Apart from the parts diagram any help with belt fitting etc. is non-existent.  I have looked again at the machine (which is very basic under the cover!) and have found a small anchor point and a hole which I now think are the spring anchors.  Thanks for your reply.
