Wristpin 399 #1 Posted February 1, 2020 I've been doing an engine overhaul on a 1980s Tecumseh 7hp iron block vertical shaft engine for another forum member; valves, ignition, charging system etc and just when I thought that I was nearing the end I've found that some vandal has carved a chunk out of the air cleaner backplate and canister. Those parts were still current on Atco 24s etc using the horizontal shaft Tecumseh H50/60 right up to the 1990s so there should be a few around, but not, it appears, in the UK . In the USA, yes, with the appropriate carriage, duty and vat etc., but not over here. If anyone has a backplate and canister to sell, please contact me - all reasonable expenses paid . Otherwise I will have to get the welding gear out, not really my forte! 1 Stormin reacted to this Share this post Link to post Share on other sites
the showman 4,074 #2 Posted February 2, 2020 Ask Nigel, he had one in a Lawn-Ranger and stopped it for a Briggs Share this post Link to post Share on other sites
squonk 71 #3 Posted February 2, 2020 I used one of those for my air compressor! Share this post Link to post Share on other sites
Wristpin 399 #4 Posted February 2, 2020 Quote Ask Nigel, he had one in a Lawn-Ranger and stopped it for a Briggs Unfortunately it is the the one!!! Share this post Link to post Share on other sites
Anglo Traction 996 #5 Posted February 2, 2020 Maybe worth checking again with Nigel. Looks the same size as fitted to H50/60,V70 etc (31715) - . I had to obtain missing parts from the states 9 years ago for this derelict H60 Rotavator as no availability in UK (used or new)- Nigel's V70 Lawn Ranger... looks pretty close without checking parts lists - Good luck with sorting it. Share this post Link to post Share on other sites
Cub Cadet 611 #6 Posted February 2, 2020 We had one on a lawn ranger engine that blew up, just looked in the box full of the broken parts but can't find it, we may have sold it. Will have another look tomorrow. 1 Anglo Traction reacted to this Share this post Link to post Share on other sites
Anglo Traction 996 #7 Posted February 2, 2020 You/Mark were my next port of call as a suggestion to Angus, as I remember the project Ewan . 1 Cub Cadet reacted to this Share this post Link to post Share on other sites
nigel 1,874 #8 Posted February 2, 2020 Yep my one is the one Angus has got , it’s knackard so if you can find it ewan that would be realy helpful 1 Cub Cadet reacted to this Share this post Link to post Share on other sites
JUST O&R 237 #9 Posted February 2, 2020 This is on ebay It does not look like he ships international but if your interested I would buy it and ship it to you. have no idea what it would cost to ship but let me know. here is asking 15.00 plus 8.61 shipping to me 1 Triumph66 reacted to this Share this post Link to post Share on other sites
Wristpin 399 #10 Posted February 2, 2020 There are two or three on US ebay but the carriage and then UK duty and value Added Tax added to the lot makes them a "luxury" item. I've got a couple of feelers out but after that its the welding set! Share this post Link to post Share on other sites
mattblack 76 #11 Posted February 3, 2020 worth a try? www.higgott.co.uk/mowerbreakers.html 1 nigel reacted to this Share this post Link to post Share on other sites
Cub Cadet 611 #12 Posted February 3, 2020 12 hours ago, Anglo Traction said: You/Mark were my next port of call as a suggestion to Angus, as I remember the project Ewan . I think the cowl went to P Mackellow, maybe the filter went with him too but ill check 1 nigel reacted to this Share this post Link to post Share on other sites
Cub Cadet 611 #13 Posted February 5, 2020 Well i've looked high and low and I can't find it anywhere. I'm normally pretty good at remembering where parts are and I can't recall seeing one since before we moved 5 years ago 1 nigel reacted to this Share this post Link to post Share on other sites
Wristpin 399 #14 Posted February 6, 2020 Thanks to all for looking but as time was moving on I got the welding gear out, made shaped paper templates , cut the sheet steel and stitched it in . A bit of a faff but got there eventually. 09CB57EA-B035-408E-A74F-0592215D7A02.MOV 3 expeatfarmer, Stormin and Cub Cadet reacted to this Share this post Link to post Share on other sites
nigel 1,874 #15 Posted February 6, 2020 Clever bogger 👍 Share this post Link to post Share on other sites
