ColinJ
Wheelhorse 512-D gearbox driveshaft bearing knackered
I am the fortunate owner of a 1986 Wheelhorse 512-D.
Unfortunately the gearbox has a knackered bearing on the input shaft.
Can anybody help with a contact that could overhaul the box? I don't have the facilities (or knowledge) to repair it.
Thanks
Colin
2 hours ago, Stormin said:
Hi Colin.
  Try Iain (Slf-uk) He's in Norfolk. He and his son Joseph are a handy pair.
Thanks - will see if I can track him down.
they aren't that hard to fix, though that input shaft is the first thing you put in when you are re-assembling - so the last thing to come out :D
happy to guide you and tell you what bearing and seal you need if you fancy a go...  I've just rebuilt one two months ago.
pulling the hubs is the hardest bit though...  then a 9/16" spanner splits the case and it's easy after that.
Many thanks for that. My problem is a lack of facilities. My normal workshop is out of commission at the moment.
I will try and get the box off and have a look and then get back to you for some more advice.
Colin
