Drumnagorrach
Flywheel Mags
Initially , I couldn’t get a spark out of the Kohler K91 fitted to my Allen Scythe .
ordered a new coil from China , couldn’t find one in UK . It turned up today and didn’t fit , the square hole through the middle is only 10 mm across flats and should be 12.5 . Being fairly annoyed , I had another go at getting a spark and after stoning the points and cleaning them again I noticed a weak spark when I spun the engine over fast with my rattle gun ,  put it all back together and it started, loads of blue smoke but pulled in the drive lever and it lurched off .
i bought it ti cut the rushes that are invading our land because the strimmer was killing my back . Not so sure the Allan scythe won’t be worse , it’s a beast 👍
