UnicycleParrot
    7
Everything posted by UnicycleParrot
  1. I'm back!!! I have had a busy summer, and i am finally getting around to posting this. I have replaced the crusty old spark plug insulation (2 layers of shrink tubing) Also, I had problems with fuel system, so I properly modified it. (maybe epoxy isn't proper I guess) Also, because I have access to a mill, I can make a compex shape for a motor mount. I also have one question. Is the air vane governor guaranteed to work? I say this because I had it running today, and it sounded like it was trying to go pretty fast (maybe hitting 2000rpm) Now, I know that these engines can hit around 5000rpm idle, I just didn't have my tach hooked up at the moment, and I didn't want to risk any damage. Can I just start it up and then walk away expecting the governor to work first time without any tweaking? Also, should my carburetor diaphragm be kind-of wrinkly? I believe it is the original diaphragm and it has not been replaced. Thanks
  2. Thanks for the advice! Is there any specific reason on why you would suggest a repair of the spark plug wire, and not just a complete replacement? Also, is there a specific gauge of wire that is best for a spark plug wire?
  3. I figured that I would cut around here, leaving a section to solder a new wire to. On the other end, I want to save the little C shaped piece to solder onto the new wire, so I plan to cut it off and solder it to the new wire. Also, what are the NOS engines that I have heard about and seen pictures on this forum. Are they bigger in some way? Or are they newer?
  4. It runs! I mixed up roughly 32:1 of fuel and 2 stroke oil and attempted to start it. At first the fuel mixture screw was way too rich (lots of fuel out of muffler), but I got it dialed in and I got a handful of 1/2 to roughly 1 second runs. Once it finally sounded like it was about to run, the spark plug wire fell off. I have a few other questions about the engine though. While I was taking apart the carburetor to check the diaphragm a little while ago, I noticed a small pinhole in the top of the carburetor. I assume this is not supposed to be there. I have repaired a hole in a carburetor on a 4-stroke engine with a 2-part aircraft epoxy. Would that work in this situation too? And about the spark plug wire (and the other wires connected to the magneto) is there anything I need to be careful about or worry about when soldering new wires in their place? Is there any type of a runaway scenario possible on an engine like this one? (imagining we had no way to kill the spark) Could the engine keep going full throttle and blow itself up?
  5. Interesting. Mine doesn't even have the oil hole for the pull starter. Just edited the first post for better pictures
  6. Thank you for such a timely and and helpful response! I do have the kill-switch piece of metal that is supposed to screw onto the top of the blower housing. I took it off when I first got the engine, because I figured it was some random thing that was on there from the previous owner. I have absolutely no experience with engines of this vintage (2 or 4 stroke) I know a few things about its life. The previous owner I never saw in person, but I hear he never used this engine. I also heard that long ago he was planning to make a minibike out of this engine. (kind of like the one you made @Wallfish) The engine has also been indoors for many years of its life (obviously) When I said "a single point" I figured it would maybe be called that because there is only one cylinder (thus only 1 set of points) I looked at the points when I first got the engine, and they are very clean. (like the rest of the engine) I also checked if it has spark, which it does. It is interesting to hear that it is an earlier model. I am a little curious if it is in better condition than others of the same vintage. Yes, deffinitely!
  7. Hello everyone. I have experience in small engine repair (mainly 4 stroke) on engines no older than 15 years old. I know how 2 stroke engines work too. I have recently obtained an old O&R engine, which seems to be in great shape. I do not know what the engine originally came off of, it also has no markings on it with a model number (or any number for that matter). One question I have is about the carburetor. Every carburetor picture I have seen on this forum has a red primer button, and a slotted jet on the top. Mine, however, has no primer button or a slotted adjustable jet on the top. Instead, there is a non-slotted knurled screw. I am also confused, because my unit does not seem to have any off switch, to stop the spark. Additionally, I am curious as to what the single point is for on an engine like this is for. On all the modern engines that I have worked on, there are no points. I have attached some pictures too for you to look at. By the way, I have not attempted to start it yet, as I am somewhat unsure of what fuel ratio it needs.
