Meon Valley Gardens 1 #1 Posted May 27, 2014 Hi All, I've just seviced the little Soverign lawn mower that i use on the allotment. It hasn't been used for a while before i seviced it. I finally got it running, replaced the diaphram, cleaned the filter, changed the oil, emptied out the old fuel, filled up with new fuel, all the rest was ok, already had a new spark plug, not much else i can do. Well finally got it going but it is running high and low, i've got a 30 second film i can send you so you can hear it (file size to big to put on here). Does anyone know what else i can do to make it run smoothly? Best Regards, Rob Share this post Link to post Share on other sites
sten 84 #2 Posted May 27, 2014 Hi, did you put the governor spring and link back on right, also check the o ring where the carb slides on the inlet pipe. Share this post Link to post Share on other sites
Meon Valley Gardens 1 #3 Posted May 28, 2014 Hi Sten, Cheers, i'll check both of these things when i get home tonight, let you know how i get on. Regards, Rob Share this post Link to post Share on other sites
