jabba
0 -
hi all just got this wosley clearway and not sure of the correct carb kit to get as no markings on it, leaks fuel as no gaskets long jet bent adjusting jet thread snapped and just pushed in, any help in direction of which kit i need or complete replacement carb be better, have looked on the bay but so many differant code models. cheers jabba
I'm guessing a Briggs with what they called large two piece flow jet. Your bent jet is typically the result of trying to separate the the two sections of the carb without removing the jet first. Overhal kits with jets and gaskets are available but we need the model, type and code numbers off the engine cowling to identify the correct one.
https://www.dropbox.com/s/k3cr1kas1lzul24/BS 2 Piece Flow Jet Carb0001.pdf?dl=0
