duradad
    8
About duradad
153 profile views
  1. Yes. I sent you a message on this. Did you get my thank you in the mail ?
  2. my Tiger generator is labeled 6v and 12v. D.C. How do you switch between ?
  3. my Tiger generator is labeled 6v and 12v. D.C. How do you switch between ?
  4. Hi. No. I don't have that part. I sent a message with my address. Thanks. Bob
  5. Thanks Wallfish. Here is a pic of my diaphragm and gasket. The rest of the carb appears exactly as in the parts diagram. I don't see any disc attached to the diaphragm. I checked the thickness. It's about .009 inches, if that helps. What do you recommend ? I'm in Connecticut 06804
  6. I have a tiny tiger carb that I thought i had disassembled very carefully. I want to replace the diaphragm and need a source. Also, I'm sure this carb has never been apart before, but I cant find any sign of the diaphragm "disc" shown on the parts list. So, I will need this also. I looked very carefully and can't see how I may have lost it. Any chance that this engine was running fine without the disc ? I don't understand how this carb pumps fuel. The pump carbs that I have worked on usually have a port hole or hose to the crankcase and the diaphragm action is via crank case pressure. Other than the primer valve. What causes the diaphragm pump action while the motor is running ?
  7. I have a tiny tiger carb that I thought i had disassembled very carefully. I want to replace the diaphragm and need a source. Also, I'm sure this carb has never been apart before, but I cant find any sign of the diaphragm "disc" shown on the parts list. So, I will need this also. I looked very carefully and can't see how I may have lost it. Any chance that this engine was running fine without the disc ?
