HeadExam
Bolens 600 tiller shaft length
Can anyone tell me the length of the rear tiller drive shaft on a 1963 Bolens 600, or if it is the same length as the later 1254, 1256, 1257 tube frames? Thanks
  On 4/13/2015 at 9:38 AM, OldBuzzard said:
I can't tell you the length, but it is shorter than the other tube frames which all use the same length shaft.
Thanks OB.
