Hoggy 0 #1 Posted January 5, 2018 A hello to all, this being my first post .. I’d be grateful if someone could steer me in the right direction regards locating some information. This particular Ransomes/Steiner 220 is Kubato diesel powered. I’m particularly after engine and charging electrical systems data, indeed as much details as possible to get this machine back into a functioning condition .. Thanks Share this post Link to post Share on other sites
expeatfarmer 591 #2 Posted January 5, 2018 Hi Do you have any photos of the Turf Trak is it the two wheel drive version? I have a 420 and two 425 models , what is it that you need to sort? Share this post Link to post Share on other sites
Hoggy 0 #3 Posted January 6, 2018 Hi ... Its the two wheeled drive version (Kuboto diesel engine) . The alternator isn't producing any electrical output, suspect it may need a repair or an exchange unit? ... haven't got a wiring diagram to test the circuit and components within the charging system prior to laying out on an alternator repair or replacement. I'm hoping to sort this problem out and give it a service. I've been asked to mow a fishery this coming spring/summer ..... the lakes are about 6 acres so the perimeter is a fair old size. I'm not familiar with this type of machine. I just want to get the Ransomes /Steiner 220 up and running reliably then I will have an opportunity of some part time work this spring/summer. ... Cheers Share this post Link to post Share on other sites
expeatfarmer 591 #4 Posted January 12, 2018 If you Google " Steiner 220 wiring diagram" you should be able to download or print one off. On the 420 and 425,s I have there is a voltage regulator under the dash with a multi plug try cleaning the terminals and check earth cables etc. Share this post Link to post Share on other sites
Hoggy 0 #5 Posted January 12, 2018 6 hours ago, expeatfarmer said: If you Google " Steiner 220 wiring diagram" you should be able to download or print one off. On the 420 and 425,s I have there is a voltage regulator under the dash with a multi plug try cleaning the terminals and check earth cables etc. Thanks for that, I will try downloading a diagram and look for the regulator tomorrow Share this post Link to post Share on other sites
