Edgar 0 #1 Posted March 27, 2018 Briggs and Stratton engine no 130232/0560/01 what is the number of the electronic conversion kit i require any reply will be much appreciated Thank you Edgar Share this post Link to post Share on other sites
Wristpin 400 #2 Posted March 27, 2018 The original coil armature on your engine would be a 298316 , to which you can fit a 394970 Magnetron module to eliminate the points and condenser but it may be less hassle to find a newer 397358 coil, that already incorporates a Magnetron trigger module, from a scrap engine. When shopping for a new / used coil take yours and make sure that the spacing of the fixing holes exactly matches as there are some minor but important differences in the spacing on otherwise similar-looking coils. Any coil from a 13 series engine should fit. Share this post Link to post Share on other sites
Edgar 0 #3 Posted March 28, 2018 Thank you for the information Edgar Share this post Link to post Share on other sites
