factory
O&R Manuals, Brochures, Adverts & Magazine Articles (& AEP, Advanced Engine Products Inc)
Ohlsson & Rice Manuals, Brochures, Adverts & Magazine Articles Thread (& Advanced Engine Products Inc)
Contents
Section 1: O&R, AEP Engine Diagrams & Instructions
Section 2: O&R, AEP Maintenance & Service Manuals & Bulletins
Section 3: O&R, AEP Brochures & Adverts
Section 4: Tool Specific Manuals, Brochures & Adverts
Section 5: Magazines Featuring Articles & Adverts (on the Web)
Section 6: TBA
Notes:
Unless otherwise specified* these are scanned from original documents that came with some of the Ohlsson & Rice engines I have, or other original literature I have bought.
*Credit is given to contributions from other forum members.
If anyone finds any errors in any of the information here please let me know & I can add a note about it.
Comments, finds, requests or errors:
Please post any comments, finds, requests or errors found in the manuals discussion thread here;
David
1960
Letter dated August 1, 1960 with the first brochure & line drawings for the O&R Ultra Compact Industrial engine, the letter has the retail prices of Models A, B, & C, the Models D, E, F were not yet available but were included in the outline drawings.
The last page of the outline drawings has the engine parts diagram & list for the Model A.
Ohlsson & Rice All New Ultra Compact Engine Aug 1960 First Brochure + Line Drawings + Parts Diagram Model A.pdf
1961
O&R compact industrial engines: engine & accessories price list (8-1-61), operation instructions (11-1-61), engine parts diagram & list for Models A, B, C & L (not dated).
Ohlsson & Rice Compact Engines Price List Aug 61 Operation Instructions Nov 61 Parts List 1961.pdf
Here is a separate PDF of just the parts diagram which isn't very clear in the above pdf.
Ohlsson & Rice Compact Engines Parts Diagram 1961.pdf
1962
O&R compact industrial engines: operation instructions (5-1-62), engine parts diagram & list for Models A, B, C (9-1-62), authorized service directory list (May 15, 1962), engine tag, warranty card and operating instructions/general information envelope.
Ohlsson & Rice Compact Operation Instructions May 62 Parts List 9-1-62 Service Directory May 62.pdf
Thank you to Razburn for pictures of the above engine parts diagram/list.
1964
O&R compact industrial engines: gear case models parts diagrams & list for Models D, E, F, G, H, J, M, N, P, R, S, T, U, V, W, X with steel gears (3-64).
Ohlsson & Rice Compact Industrial Engines Gear Cases Mar 1964.pdf
1965
O&R compact industrial engines: engine parts diagram & list for Models A, B & C, Compact I, II & III engines (11-65).
This also covers parts used on engine Types 101, 118, 121, 126, 129, 132, 133, 136, 137, 139, 142, 143, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 157, 158, 159, 160, 161, 163, 164.
Ohlsson & Rice Compact I II III Engines Parts Nov 65.pdf
1970's
O&R engines: engine parts diagram & list for the Type 13B252 engine (Oct/70, Feb/72) with parts list supplement (Jun 71).
Ohlsson & Rice Type 13B252 Engine Parts Diagram & List 1970 Feb 1972 & Supplement June 1971.pdf
O&R engines: engine parts diagram & list for the Type 20A-256 engine (undated, possibly 1971 or earlier)
Ohlsson & Rice Model 20A-256 Engine Diagram + Parts List.pdf
David
Model 20A Maintenance Manual
Ohlsson & Rice maintenance manual for the Model 20A 1.6HP 2c.i.d engine (2/72).
Ohlsson & Rice Model 20A Maintenance Manual Aug 72.pdf
Notes: I have found two errors in this manual so far, if anyone finds any more please let me know so I can add a note here.
Error 1: Part numbers for the Walbro carburetors on page 6, I have two HDC6 carbs with a right angled fuel inlet, but the manual shows HDC6 below the wrong picture. HDC11 is correct, can anyone confirm the others (HDC13 & HDC14) are correct?
Error 2: Page 2 states that the spring housing should be turned 1 to 1½ turns to wind the starter spring, figure 7 on page 4 states to turn spring housing 1½ to 2 turns, Service Bulletin S-E095 (Oct 1972) confirms that it should actually be 1 to 1½ turns.
Starter Repair Procedures
Service Bulletin S-E-040: starter spring & cord installation instruction (Sept 1969).
This is for earlier engines with the short (44") starter cord used up to serial number #099151, the starter spring is also shorter & is held in place with a small retaining clip.
Ohlsson & Rice Service Bulletin S-E 040 Sep 69 Installation Procedure Old Style Starter Spring and Cord.pdf
O&R Engine Series 13A starter mechanism operating instructions (2/72).
This is for later engines with the long (54") starter cord used after serial number #099151, the starter spring is longer & the starter reel is held in place with a retaining ring.
Ohlsson & Rice Series 13A Starter Mechanism Feb 1972.pdf
Note: It may get confusing which procedure to use if the starter or parts of it have been swapped in the past.
David
1960?
Ohlsson & Rice Ultra Compact Engine brochure (not-dated).
Ohlsson & Rice Ultra Compact Engine.pdf
1975
Advanced Engine Products Incorporated (AEP) Series 13B Engine Brochure (Aug 1975).
Advanced Engine Products Series 13B Engine Specifications Aug 1975.pdf
Advanced Engine Products Incorporated (AEP) Series 20A Engine Brochure (not-dated).
Advanced Engine Products Series 20A Engine Specifications Not-dated.pdf
David
Bridges 3-Speed Mini Mota Drill
Operating instructions, specifications and engine/gearbox parts diagram & list (not-dated).
Bridges 3 Speed Mini Mota Drill Operating Instructions and Parts List.pdf
Drillgine
Magazine advert for Drillgine distributed by Bartlett Mfg. Co. (dated 1967, title of magazine is unknown), first page is actual size and second enlarged. Thanks to Webhead for finding this one.
Drillgine Bartlett Mfg Co magazine advert 1967.pdf
Nichols Generator
Operating manual for the Nichols Super Portable Power-Pack Model 'D' with parts diagram & list from Nichols Industries Inc. (not-dated) May also be useful for the Creme Lure Co. version. Thanks to Just O&R for the PDF scan.
Nichols Super Portable Power-Pack Model D Operating Manual.pdf
Octura Catalogues & Brochures
Octura Models Aerokits Sea Queen brochure, powered by the Ohlsson & Rice Compact III engine (not-dated). Thanks to Daren89 for PDF
Aerokits Sea Queen Octura brochure.pdf
Octura Models drivline fittings diagrams. Thanks to Daren89 for PDF scan.
Octura drivline.pdf
Octura Models price list for model boat fittings, engines, plans, etc. (May 1969). Thanks to Daren89 for PDF scan.
Octura Catalogue May 1969.pdf
Octura Models White Heat V brochure, powered by the Ohlsson & Rice Compact engine (dated 1962). Thanks to Daren89 for PDF scan.
Octura White Heat V Brochure.pdf
Octura Models White Heat X brochure, powered by the Ohlsson & Rice Compact III engine (dated 1962, but the CIII engine is later). Thanks to Daren89 for PDF scan.
Octura White Heat X Brochure.pdf
Octura YE Compleat R/C Boater new products newsletter. Thanks to Daren89 for PDF scan.
Octura YE Compleat.pdf
Orline Challenger Chain Saw
O&R Engines Inc maintenance manual for Challenger chainsaws fitted with the Model 20A engine (not-dated).
Ohlsson & Rice Challenger Chain Saw Maintenance Manual.pdf
Orline Circular Saw
Parts diagram & list for the circular saw (1/71), includes the Type 218 engine parts diagram & list (9/68).
Ohlsson & Rice Circular Saw Jan 71 & type 218 engine Sep 68.pdf
Orline Compressor
Operating instructions (5/69) & parts diagram for the compressor frame only (11/69).
Note: I suspect the operating instructions is missing a page.
Ohlsson & Rice Orline Compressor Parts List & Operating Instructions 1969.pdf
Orline Gusher Pump
Part diagram & list for the pump only (10/70).
Ohlsson & Rice Gusher Pump Parts List Oct 70.pdf
Perry Aquabug Outboard Motor
Owner's Manual for the Aquabug outboard motor (rebranded by R. Perry & Co. Ltd) (not-dated).
Perry Aquabug Owner's Manual.pdf
Regina Champ Generator
Instructions for Regina Electric Products Ltd. Champ petrol engine driven alternator, covers Models H110, H111, H112, H113 & H114 and guarantee card (not-dated).
Regina Champ Petrol Engine Driven Alternator.pdf
Tiny Tiger Generator
Operating & maintenance instructions for the late 1960's Tiny Tiger generator made by Holly Products Corporation, covers Models 5001-1, 5001-2, 67 and accessories (not-dated).
Tiny Tiger Generator Operating Instructions Models 5001-1 & 5001-2.pdf
Note: this was originally printed as a large fold-out manual, pages 2 to 4 are one side & pages 5 to 7 the other side, there is some overlap of pages in the pdf because of the diagrams.
Wards Model 10 Digger
Owner's guide and parts list.
Unfortunately not the best copy as it's been folded and very dirty. Thanks to Wallfish for adding this one.
Wards Model 10 Digger manual.pdf
David
Most of these have been scanned by Google, click on the page numbers to go to the relevant part of the magazine on Google books (or other sites where indicated), also note that some of them don't have pictures.
Boating Magazine, Popular Boating Magazine
February 1963 page 12? Tiny Tiger Generator.
November 1973 page 98 Dyna-Mite Generator.
Flying Magazine
July 1963 pages 16 Tiny Tiger Generator & 17 Lineboy Towbar.
Mini Bike Guide
November 1971 pages 49 to 51 & 65 (Holder Micro Cycle), from oldminibikes.com.
Motor Boating Magazine, Motor Boating & Sailing Magazine
February 1966 page 53 General Equipment Co. Ice Auger.
November 1969 page 35 Tiny Tiger Generator.
June 1972 page 8 Aquabug Outboard.
National Maple Syrup Digest
January 1964 page 15 King Drillgine, from maplesyrupdigest.org.
Organic Gardening and Farming Magazine
??? 1966 page 20 Merc-O-tronic min-i-pump Model 600, from ebay sold listings
Popular Mechanics Magazine
April 1962 pages 128 to 130 Krestronics Charge-R-Lite Generator.
June 1962 pages 124 to 130, 186 to 188 & 190 White Heat V Hydroplane.
September 1962 page 56 Tiny Tiger Generator.
June 1963 page 137 Petro Chug-A-Saw Chainsaw.
October 1963 page 163 Orion Drillgine.
January 1964 page 162 Varo Amp-Champ Generator.
April 1964 pages 182 to 189 Tom Thumb Scooter Mini-Bike (Part One).
May 1964 pages 165 to 169, 185 & 186 Tom Thumb Scooter Mini-Bike (Part Two), from archive.org.
December 1964 page 24 Polaris Power Pole Auger.
January 1965 pages 129 & 130, 222 Polaris Power Pole.
July 1965 pages 84 & 85 Halicki Skateboard.
July 1969 page 51 Calif. Power Line Products Inc. Chainsaw.
August 1969 page 33 Calif. Power Line Products Inc. Chainsaw.
September 1969 page 221 Calif. Power Line Products Inc. Chainsaw.
January 1970 pages 168 to 171 Tom Thumb Mini-Bike.
June 1970 page 181 Orline Amp-Champ Generator.
July 1970 page 161 Orline Model 249 Hedge Trimmer.
May 1972 pages 21 & 22, 24, 190 Steam Mini-Bike.
July 1974 page 174 Chicken Power Bike Kit.
November 1974 page 196 Chicken Power Bike Kit.
December 1974 page 181 Chicken Power Bike Kit.
October 1976 page 191 AEP Service Training.
May 1978 page 6 AEP Pony Express Bike Kit.
June 1978 page 198 AEP Pony Express Bike Kit.
Aug 1978 page 155 AEP Pony Express Bike Kit.
Popular Science Magazine
June 1961 pages 64 to 67, 208 & 209 New Ohlsson & Rice Engine, Various Applications & page 217 Speedy Sprayer (not O&R but related).
January 1962 pages 191 & 192, 194 & 214 Comet C/Saw & Savidge Drill.
March 1962 page 172 Krestronics KGC-3 Generator.
April 1962 page 32 Chip-A-Saw Chainsaw, Orion Drillgine & Petro Drill.
July 1962 page 152 Irvington Mini Winch.
January 1963 page 157 Nichols Dyno-Mite Generator.
May 1963 page 189 Tiny Tiger Generator.
May 1964 pages 112 to 114 Tiny Tiger Generator.
December 1970 pages 20, 22 & 26 Orline Sno-Tiger Snow Thrower.
June 1971 pages 69 Orline Mark II Chainsaw & 133 Helpmate Mini-Automatic Chainsaw.
June 1972 page 18 Wards 30-Inch Trimmer.
May 1977 page 50 AEP Estate & Landscaper Trimmers.
May 1978 page 123 AEP Groomer Trimmer.
The Quarterly Skateboarder
Spring 1965 page 11 Tiger-Skate & Tiger-Bike, from vintageskateboardmagazines.com.
David
Guest
This topic is now closed to further replies.
