Charioux 16 #1 Posted February 26, 2014 Hello I need to know if the Kohler engines K301 K321 and K341 (from 12 to 16hp) have the same crankshaft and camshaft as the stroke is the same in the three models If you understand, can somebody give an answer? Thank you Share this post Link to post Share on other sites
Anglo Traction 1,018 #2 Posted February 26, 2014 Hello André, I have checked each of the 3 Models you specified using random Spec Number versions for each Kohler Model. I used numbers from the 1970s to check them. All 3 Engine Parts Manuals quoted the same Part Number (45-142-21-S) for the Crankshaft. Note that there will be differences in the Crankshaft according to the Application (Spec Number), but the Journal spacing and dimensions are the same, and as you mentioned, so is the 'Throw' (or Stroke). If you need more assurance, Post the Spec and Serial numbers numbers of the 3 engines, I'll try and check them for you. Hope this helps. Regards. Share this post Link to post Share on other sites
Charioux 16 #3 Posted March 15, 2014 Hello Anglo Traction I apologize for having let this post for a while Many thanks for your info and help Share this post Link to post Share on other sites
