tvenetis 0 #1 Posted October 19 (edited) I took the plug outlet apart on a tiny tiger generator and spread the 2 contacks because they were not making good contack when i plugged some thing in to it. I put the plug back in with the wires inserted and I put the center u piece with a screw which held the plug in. I noticed that after the screw was snug there was nothing holding the 2 plug pieces that had the wire solder to them in. You can just pull the wires out of the socket. What I am trying to ask is that after the plug recepticle is screwed in to the rear housing of the generater, when you plug something in to it what prevents the 2 wires from comming out of from the plug socket. Edited October 19 by tvenetis revise it Share this post Link to post Share on other sites
tvenetis 0 #2 Posted Monday at 03:00 PM (edited) I found out that the plug broke so i ordered one from amazon. Does any one have a schematic for the generator? One of the wires that went to the outlet came off and I can't find where it goes. It is the black wire that comes from the outlet. We looked on the Stator but did not see where it should go. Edited Tuesday at 06:47 AM by tvenetis revise it Share this post Link to post Share on other sites
