Potash123
Roybi RSV 3100E leaf blower.
Hi Lads. looking at a hand held RSV 3100E which was given to me. The fuel lines and primer were present but not fitted as they had gone brittle. I bought a new bulb- primer and pipes, all fitted BUT I can't see which of the two pipes fits which connection on the carb. I have found a few parts
list but they don't show the connections. The connections on the bulb and different lengths which indicated the flow. HELP please.
I have connected the pipes and primed the system. Petrol is flooding straight into the engine. It is a Walbro Carb. Would it be a diaphragm ?
It's pouring into the combustion chamber at quite a rate. I will get a rebuild kit, they are cheap. Would having the pipes in wrong order let this happen, Thanks.
