majorxlr8n
Members-
10 -
About majorxlr8n
Thanks John! again, thanks to you fine folks for helping! I do have the carb set slightly rich. I always prefer to have my 2 cycles run that way instead of lean.
IMG_0509 (1).MOV lets try this... https://www.youtube.com/watch?v=98SOYslNs6A
SUCCESS!!! http://vid17.photobucket.com/albums/b81/kingmags/IMG_0509%201_zpswy18cd11.mp4 I cannot thank you folks enough! the fishing line trick to install the lever arm retainer in the carb worked well! it took a few tries but I finally got it all together. I had to set the mixture needle about 3/4 turn out from the seated position. it took awhile to get back to this project but it was worth it! Again, MUCH THANKS!!! Marty
ok, the ball must had gotten dislodged. I got lucky - it was still under the lever but not in place. I was able to get it seated by tilting the base around and lightly moving the lever arm until it fell into place! WHEW!! now to find the new diaphragms - they got misplaced I'm SOOOOOOO close to getting this O&R running!! thanks again! Marty
How do you keep track of your equipment information?
majorxlr8n replied to slf-uk's topic in Off-Topic Discussion
if you have a smart phone, create a file (note) for all your machines. I use it to keep track of customer jobs/machines. I also use the contact info for storing model & serial numbers associated with each customer -
majorxlr8n started following O & R Carb Repair Tutorial and How do you keep track of your equipment information?
Indeed!! just in time for my carb surgery. MUCH THANKS!!!! Marty
Thank you John & David - now to get back to work on this. appreciate the help! Marty
I wish I had rebuilt my carb while the old O&R forum was available with that FANTASTIC tutorial... I finally had a chance to get back to my Tiny Tiger generator. I disassembled the carb. I remember reading about a ball that sat under the diaphragm lever. Now, when I blow thru the inlet hose, there is constant air flow whether the arm is at rest or depressed. That doesn't sound right. Also, should the correct re-assembly be: top cover, diaphragm, disk? it looks like the metal disk sits directly on the lever on the "dished" side. The carb to engine gasket has a small rubber check valve as part of a gasket. it is not seated. should that be replaced? sorry for all the questions but I greatly appreciate the help/guidance! Marty
