I wish I had rebuilt my carb while the old O&R forum was available with that FANTASTIC tutorial...
I finally had a chance to get back to my Tiny Tiger generator. I disassembled the carb. I remember reading about a ball that sat under the diaphragm lever. Now, when I blow thru the inlet hose, there is constant air flow whether the arm is at rest or depressed. That doesn't sound right.
Also, should the correct re-assembly be: top cover, diaphragm, disk? it looks like the metal disk sits directly on the lever on the "dished" side.
The carb to engine gasket has a small rubber check valve as part of a gasket. it is not seated. should that be replaced?
sorry for all the questions but I greatly appreciate the help/guidance!
Marty
