greenplane
About greenplane
    east yorkshire
1,669 profile views
  1. It is a foam Filter So I will try this, the Needles I have taken out inspected and cleaned gently as there was some slight green on brass corrosion, the manual I do have but It is very sketchy But I only have the manual for the engine as in the Briggs and Stratton engine , not the complete machine I have a parts and exploded view but that's it . I will clean the filter out like earlier suggested. But I notice that the choke butterfly stays horizontal at all times it doesn't seem to go vertical (closed) at any time .The Machine was outside in east yorkshire for a long period of time close to the sea. Any further Ideas would be a great help. I know about engines etc but only RC car nitro's and 2 strokes the carbs on those are easy to fix in comparison to this one , I know its similar just larger, but it doesn't seem to be as simple, or as easy to remedy
  2. My Carb looks like the pictures you sent and seems to work the same , though still starts but not wanting to keep running , I took the filter out as that's soaked in oil and black in colour, therefore I'm getting a new one. the internals of the car are clean, though I did notice at some point it has had some corrosion, the jets are cleaned out (did that).Cleaned the plug (just in case My late father would say) So what now? I have the throttle lever over to the furtherest position on the right (as you stand behind) then tweaking it slow towards the left. The fuel is good. Help?????
  3. tHANK YOU FOR YOUR HELP , THOUGH HOW DO YOU KNOW IF YOU HAVE THE RIGHT SETTINGS FOR THE CARB SCREWS, AS I DO NOT HAVE A MANUAL OR INSTRUCTIONS apologies for the caps , i forgot it was on as just been doing some flyers for my Rc car business Cheers Mike
  4. Thanks Chris , any ideas where I get a new one from?
  5. Hi All Got my Osprey started , however it wont keep running it runs for around 10-15 seconds then dies , is easy enough to restart but does the same. has any one any ideas to the problem? and a solution please Cheers Mike
  6. Hi all abit new here, just got a inexpensive Hayter Osprey . now need to know how to start it as there doesnt seem to be a choke?? Thanks Mike
