majorxlr8n 2 #1 Posted November 28, 2014 (edited) I wish I had rebuilt my carb while the old O&R forum was available with that FANTASTIC tutorial... I finally had a chance to get back to my Tiny Tiger generator. I disassembled the carb. I remember reading about a ball that sat under the diaphragm lever. Now, when I blow thru the inlet hose, there is constant air flow whether the arm is at rest or depressed. That doesn't sound right. Also, should the correct re-assembly be: top cover, diaphragm, disk? it looks like the metal disk sits directly on the lever on the "dished" side. The carb to engine gasket has a small rubber check valve as part of a gasket. it is not seated. should that be replaced? sorry for all the questions but I greatly appreciate the help/guidance! Marty Edited November 28, 2014 by majorxlr8n Share this post Link to post Share on other sites
Wallfish 716 #2 Posted November 28, 2014 Yes, the disc sits directly on the arm. The clear check valve gasket sits against the diaphragm body so it valves the little hole going to the carb body. Here's a carb drawing showing all the parts. The little bearing ball is a must have so check your carb to make sure it is still in there if you think it might be missing. No worries on ANY questions, that's why we're here! Share this post Link to post Share on other sites
factory 487 #3 Posted November 28, 2014 (edited) You can still find the old carb repair thread with pictures at the internet archive. http://web.archive.org/web/20131129041923/http://ohlssonandrice.forumer.com/carb-repair-t1184614.html David Edited November 28, 2014 by factory Share this post Link to post Share on other sites
majorxlr8n 2 #4 Posted November 28, 2014 Thank you John & David - now to get back to work on this. appreciate the help!Marty Share this post Link to post Share on other sites
majorxlr8n 2 #5 Posted November 29, 2014 ok, the ball must had gotten dislodged. I got lucky - it was still under the lever but not in place. I was able to get it seated by tilting the base around and lightly moving the lever arm until it fell into place! WHEW!! now to find the new diaphragms - they got misplaced I'm SOOOOOOO close to getting this O&R running!! thanks again!Marty Share this post Link to post Share on other sites
majorxlr8n 2 #6 Posted January 22, 2015 (edited) SUCCESS!!! http://vid17.photobucket.com/albums/b81/kingmags/IMG_0509%201_zpswy18cd11.mp4 I cannot thank you folks enough! the fishing line trick to install the lever arm retainer in the carb worked well! it took a few tries but I finally got it all together. I had to set the mixture needle about 3/4 turn out from the seated position. it took awhile to get back to this project but it was worth it! Again, MUCH THANKS!!!Marty Edited January 22, 2015 by majorxlr8n Share this post Link to post Share on other sites
Wallfish 716 #7 Posted January 22, 2015 Nice! The video link won't play because it says it's corrupt Share this post Link to post Share on other sites
majorxlr8n 2 #8 Posted January 23, 2015 IMG_0509 (1).MOV Nice! The video link won't play because it says it's corrupt lets try this... https://www.youtube.com/watch?v=98SOYslNs6A Share this post Link to post Share on other sites
Wallfish 716 #9 Posted January 23, 2015 That link works, thanks. Sounds like it's running good Share this post Link to post Share on other sites
majorxlr8n 2 #10 Posted January 24, 2015 Thanks John! again, thanks to you fine folks for helping! I do have the carb set slightly rich. I always prefer to have my 2 cycles run that way instead of lean. Share this post Link to post Share on other sites
Richard Carr 1 #11 Posted December 26, 2017 Need carb diapharam for tiny tiger.webhead.Thanks.Rick carrwer@aol.com 2406202310 Share this post Link to post Share on other sites
