Rocboni 257 #1 Posted May 11, 2015 (edited) I am building a replica machine and require what I believe to be called admirality plate, it's an old style of tread plate with dimond shapes on, I am aware of the modern steel plate that you get but it does not have the correct pattern. If anyone has seen this or has a bit lying about then I would be greatfull if you would pass it on, I've been to just about every blacksmith, engineers and scrap yard in the borders and no one has seen it. I require two pieces around 12" square I have a piece so I know it exists! Edited May 11, 2015 by Rocboni Share this post Link to post Share on other sites
nigel 1,881 #2 Posted May 12, 2015 have you tried down the councel highways yard cos they used to use that down our way. worth a try anyway Share this post Link to post Share on other sites
Rocboni 257 #3 Posted June 2, 2015 I have sourced some plate so no longer required, thanks. Share this post Link to post Share on other sites
