Ian 2,417 #1 Posted March 9, 2017 Hi all, I have this galvanized steel pipe taking up space in my workshop, I'm never going to use it so it must go. 3mm wall thickness, 75mm diameter, over 50ft in total. Oh, and the galvanization is very thick so they should outlast most of the planet I was going to build a lathe bench with it so it has been cut into handy lengths. 2 X 8 ft 6 inches, one of which has a slight bend 2 X 8ft 4 X 6ft 2 X 4ft 6 inches. A couple of them as you can see have a few welding marks which will easily grind off. Use them to build a car port, heavy duty washing line pole, or even use them to build the ultimate spud gun Collection from Hawkhurst, Kent. I'm not quite sure what this is worth so let's start at £100 and you can barter me down a bit Share this post Link to post Share on other sites
nigel 1,880 #2 Posted March 9, 2017 £1.00 is my offer 🙄 If you deliver them Share this post Link to post Share on other sites
