Morrisoft
O&R 0.85hp (tiny tiger) - Carburetor parts? Coil refurb?
4 hours ago, Webhead said:
I think David is right, it's probably somebody's replacement for 131 or 15 on your photo.
Exactly what I thought, I guess original spares were probably more difficult to find before the internet existed, especially in countries with few or no service shops or parts distributors for O&R's.
David
19 hours ago, Morrisoft said:
Interesting - the very same supplier I used for the NGK. I think maybe I took their last CM6 then, as they didn't have any others on their eBay store. It's certainly 10mm which is good to have confirmed. Almost identical to the one it replaced other than a slightly different washer on the thread.
I had thought around 1965 as this was when the gentleman who owned it mentioned purchasing it, just wondered if there were exact dates but a confirmation of 1965 is suffice.
It's interesting to note that yours too has a different screw for one of the 4 tank mounts. Mine is simply a hex bolt of the same length, I assume due to lack of clearance around the engine for a screwdriver to reach it without completely dismantling all shrouds first.
Is bluing like oil blacking, or are they the same think by a different name? Tempted to give it a try if this is the case as I've done this before.
Cheers,
Still available according to their website;
http://www.gsparkplug.com/1x-ngk-copper-core-spark-plug-cm-6-cm6-5812.html
Seems to be the spark plug used on the 1960's Honda E300 generator.
The parts list that came with my Tiny Tor is dated August 1964, the next update of the parts diagram I have is dated November 1965, so a date of around 1965 is probably right.
They only used the fourth threaded hole in the tank on the earliest engines, which had a stud/nut fitted below the carb. The different screws fitted here are none original. I guess they never changed the tank design though.
5a11d66bd6ec9_OhlssonRiceCompactIITankMountPartsDiagramAug64.jpg.fc1eef7aae368c017f47c7e85ab2d140.jpg
Steel bluing giving a black oxide finish is not the same as oil blacking as far as I know, the bluing process involves various chemicals depending on the process used, oil can be used at the end of the process for rust prevention;
https://en.wikipedia.org/wiki/Bluing_(steel)
https://en.wikipedia.org/wiki/Black_oxide
Have a look on youtube for bluing of guns or knives to see the process.
Looks like there are two methods for oil blacking, dipping heated parts in oil or baking oiled parts, some info here;
http://www.practicalmachinist.com/vb/general-archive/oil-blackening-rust-protection-84713/
David
On 10/11/2024 at 8:36 AM, alexandre69 said:
Hi im alex from france. I need to find a New condensator and New high tension coil.
Someone could help me? Thanks a lot in advance
It's not very common for one of these coils to fail, except the early models had a smaller tension plug wire that could more easily get damaged.
I'm assuming your engine does not have spark. Have you cleaned the point contacts under the flywheel? If you parts are not damaged you may not need parts.
How are you? We did all test and its really broken. We need to change them. Do you have idea where to find them? Thanks in advance
@factory David may be able to help you out as he's from UK, but he hasn't been as active on here recently.
I have a Tiny Tiger Model 300 with a Ohlsson & Rice engine. When reassembling the carburetor we broke the needle valve housing. Does anyone know where I might find one? Thank you!
:WMOM:
Think I can find a spare.
Where are from?
Do not use a wrench to tighten them and they don't need to be very tight either.
On 2/7/2025 at 9:43 AM, RandyC said:
I am at 101 N. Sigler Street, Kingwood, West Virginia 26537. Let me know how much you want for it.
Thank you so much!
I'll poke around for one those today. Do you already have a new carb diaphragm to install?
I have one that someone made. I am not sure how well it will work yet.
I am at 101 N. Sigler Street, Kingwood, West Virginia 26537. Let me know how much you want for whatever you can find.
Thank you so much!
