Anglo Traction 998 #1 Posted October 26, 2018 Genuine Kohler parts now surplus to my needs. Was for a K341 job- These kits are often seen/sold as (aftermarket) able to fit the whole range of engines. The Kohler Manual states different part numbers for various Carb numbers. I have established that the small difference appears to be the bore size of the float valve body. Otherwise, these appear to be same dimensions as the 25 757 01-s Kit. If you wish, I can check your KOHLER Carb number. Note this is for Kohler, not WALBO Carbs. £12. posted to UK address. Share this post Link to post Share on other sites
Stormin 4,458 #2 Posted October 26, 2018 Subject to carb number consider kit sold. I'll check tomorrow. Been wielding a chainsaw all day and feeling a little jaded. Share this post Link to post Share on other sites
