I have and old hayter osprey and the drive is not working looking for advice on it. Have made a start on striping it down
If you look back through older posts , I have,  time to time posted scans of pages from various Hayter piublications. Assuming that the worm drive box has not destroyed itself through lack of lubrication  it is mainly a matter of eliminating / compensating for wear to get a “ good clutch”  - one that both drives well and disengages cleanly.
As Wristpin says, there is much of what you are looking for already here. If you use the 'Search' box (top left), you will find many. Just using the word 'Osprey'  throws up this number of posts-
If you  use 'more search options', you can select Topic titles only search to give you a list of Topics on the same issues with this machine.
The Opsrey is a self powered machine, so most topics on it are in the 'Other Garden Machines.
Some links to manuals in threads are broken, so if you need any more help just ask.
No problem using an old thread to post/ask a question, as it prevents the same questions/Topics being asked over and over again.
