CNew 407 #1 Posted April 5, 2019 This is probably already known here but in case anyone is looking for a replacement seal/gasket for the intake flange where it connects to a gearbox, here is a square profile O-ring that I found from McMaster-Carr that looks like a good option. It’s Part# 4061T231 and is 11/16 ID so it make a nice snug seal on the flange. Share this post Link to post Share on other sites
factory 487 #2 Posted April 5, 2019 Looks like a good replacement. Also I've changed the title to the correct name for this part (#7-46 gear case sealing washer). David Share this post Link to post Share on other sites
CNew 407 #3 Posted April 5, 2019 David, Thank you for updating the title, that’s much better! Clint Share this post Link to post Share on other sites
factory 487 #4 Posted April 5, 2019 No problem Clint, I thought it was a good idea as these seals only seem to be used on engines with the reduction gearboxes. Also it seems we don't have McMaster-Carr over here in the UK, I guess I should be able find something similar. David Share this post Link to post Share on other sites
CNew 407 #5 Posted April 5, 2019 David, Let me know if at some point you need a couple. Clint Share this post Link to post Share on other sites
