factory 487 #1 Posted May 18, 2019 This may be of interest on here, a vintage model plane with an early Ohlsson & Rice 3/4HP engine, the wingspan is 7ft, the engine is SN 007860 dating from around 1961. The only replacement parts I can see are magneto coil and a complete later carb primer assembly & needle valve, the original side mounted needle valve has been blocked off. As it has been converted to RC control with a servo & cable for the carb throttle control, the redundant governor vane has been removed too. Model plane on eBay.com David Share this post Link to post Share on other sites
CNew 408 #2 Posted May 18, 2019 David, Cool - I contacted this seller weeks ago to let him know that he had an O&R on there. I recommended he realist it with O&R so that maybe he could get a bit more interest. It’s a neat plane but too much $$ for me. Share this post Link to post Share on other sites
factory 487 #3 Posted May 19, 2019 The market is also going to be limited to people that are near enough to collect it from Salinas in California. David Share this post Link to post Share on other sites
