Rayp 48 #1 Posted July 16, 2019 The belt broke on my wheeled trimmer and having replaced it I am struggling to locate the location for the ends of the return spring (part no. 15 on the attached parts diagram). Can anyone help please? Share this post Link to post Share on other sites
JUST O&R 237 #2 Posted July 17, 2019 ON THIS TRIMMER DO YOU HAVE A HANDLE TO ENGAGE THE HEAD ? IF SO THE SPRING HAS TO DISENGAGE THE BELT SO IT NEED TO PULL THE IDLERS BACK AWAY FROM THE BELT. NOT SURE WARE THAT SPRING HOOKS . BUT IT HAS TO PULL BACK TO TO RELEASE THE PRESSURE FROM THE BELT Share this post Link to post Share on other sites
Rayp 48 #3 Posted July 19, 2019 Yes the handle does have a lever to engage the head. Apart from the parts diagram any help with belt fitting etc. is non-existent. I have looked again at the machine (which is very basic under the cover!) and have found a small anchor point and a hole which I now think are the spring anchors. Thanks for your reply. Share this post Link to post Share on other sites
