James 0 #1 Posted August 25, 2020 I have recently started using a clients Wolseley Clearway which is a fantastic machine. Unfortunately, the Tensioner Pulley has broken away from it's spindle - see attached pictures. I believe the pulley and spindle should be one unit. Would anyone be able to provide any information as to where I could source a new part? Most mower repairers have said it is impossible to get the parts. I'm hoping that there must be some parts somewhere around. Thanks. Share this post Link to post Share on other sites
mattblack 76 #2 Posted August 25, 2020 It doesn't look anything special, I'd have thought a local industrial/bearing supplier could sort you out if you took it in. Share this post Link to post Share on other sites
James 0 #3 Posted August 25, 2020 Thanks for this information. The pooint that concerns me is that the spindle and the pulley are one. There is a grease nipple on the end of the spindle. Would this be common at a bearing supplier? Share this post Link to post Share on other sites
Stormin 4,458 #4 Posted August 25, 2020 What held the pulley on the spindle? Maybe a circlip. Take the spindle of and photo' the end of the spindle. If the bearings in the pulley are ok, then a new circlip and some Loctite bearing fit should see you right. Welcome to MoM BTW. And where are you located. Maybe someone near you who can help. Share this post Link to post Share on other sites
mattblack 76 #5 Posted August 25, 2020 (edited) 35 minutes ago, James said: Thanks for this information. The pooint that concerns me is that the spindle and the pulley are one. There is a grease nipple on the end of the spindle. Would this be common at a bearing supplier? You may not get something exactly the same but I think you'd get something that would do the same job. Replacement may be a sealed bearing without the grease nipple. Edited August 25, 2020 by mattblack Share this post Link to post Share on other sites
