Rayp 48 #1 Posted September 23, 2020 Has anyone got a spare cowling for a 5HP Briggs & Stratton vertical crankshaft engine (like that in the photo). I think the part no. was 392277 and is now 490192? Share this post Link to post Share on other sites
nigel 1,880 #2 Posted September 26, 2020 I think I have one kicking about will have a look on monday 1 Rayp reacted to this Share this post Link to post Share on other sites
Rayp 48 #3 Posted September 27, 2020 Thanks Nigel - that will be great if you have one. I couldn't believe it when after refuelling I pulled the starting rope and the whole cowling can off. The 3 bolt holes had 'enlargened' so I put some repair washers on, bending the two front ones to fit the curvature of the cowling and managed to almost finish the paddock I was mowing when it came off again. It seems to be a problem with Hayter 21s that even with spring washers bolts need more frequent checking to ensure that the vibration of the engine has not loosed them. Ray Share this post Link to post Share on other sites
nigel 1,880 #4 Posted October 2, 2020 This is the only one I have ,any good Ray ? Share this post Link to post Share on other sites
Rayp 48 #5 Posted October 4, 2020 Hello again Nigel. Thank you very much for hunting out the cowling, but regrettably it doesn't look like it will be a suitable replacement. I have now taken some photos of my Cowling (which I should have done in the first place!) and they are attached. Yours seems to be a differing shape and have the fixings in different positions. You can see in the photos that all 3 fixing holes have 'enlarged' and a crack is appearing above the one next to the throttle clip so I think its days are numbered. I'll have to look out for a scrapped engine from a Hayterette or another 21. Share this post Link to post Share on other sites
nigel 1,880 #6 Posted October 4, 2020 I will have another look tomorrow Ray Is yours made of cast alloy ? Share this post Link to post Share on other sites
Rayp 48 #7 Posted October 5, 2020 Hello Nigel, The recoil housing is alloy, but the main cowling (the part I need!) is steel. Ray Share this post Link to post Share on other sites
Rayp 48 #8 Posted October 10, 2020 Good news Nigel!- I happened to spot one on Ebay and it has now arrived and been fitted. Share this post Link to post Share on other sites
nigel 1,880 #9 Posted October 11, 2020 Ah brilliant Ray 👍 Share this post Link to post Share on other sites
