Rayp 48 #1 Posted February 2, 2022 Can anyone help please with a picture or diagram of what fits where on the control unit. It is some time since I dismantled my engine and although I took (the attached) photo of the unit, it is of little help now I wish to reconnect the carburettor, Governor choke and killer switch and nor is the parts and service manual!. Share this post Link to post Share on other sites
Wristpin 400 #2 Posted February 3, 2022 BS Model, Type and Code will help. Share this post Link to post Share on other sites
Rayp 48 #3 Posted February 4, 2022 The numbers on the engine cowl are:- 170702 5638-01 80082211. There is also a spring which has several possible fixing points and the correct one is not obvious to me! Share this post Link to post Share on other sites
Wristpin 400 #4 Posted February 6, 2022 None of my manuals are very helpful as none has a clear illustration of what I remember as being the setup on an Osprey. I will scan and post the nearest 1707** images that may just assist a bit. Looks like no outdoor work to day so will do that this pm. Share this post Link to post Share on other sites
Wristpin 400 #5 Posted February 6, 2022 This is the best I can find - may be what you have. https://www.dropbox.com/s/t38hv0y8fjacgvp/Briggs 170000 throttle and governor control0001.pdf?dl=0 Share this post Link to post Share on other sites
Rayp 48 #6 Posted February 7, 2022 Thankyou Wristpin, that does look like mine, is much clearer than what I have and should be helpful in making the connections. Share this post Link to post Share on other sites
