Rayp
Hayter Osprey throttle control unit
Can anyone help please with a picture or diagram of what fits where on the control unit.  It is some time since I dismantled my engine and although I took (the attached) photo of the unit, it is of little help now I wish to reconnect the carburettor, Governor choke and killer switch and nor is the parts and service manual!.
The numbers on the engine cowl are:- 170702    5638-01   80082211.  There is also a spring which has several possible fixing points and the correct one is not obvious to me!
None of my manuals are very helpful as none has a clear illustration of what I remember as being the setup on an Osprey. I will scan and post the nearest 1707** images that may just assist a bit. Looks like no outdoor work to day so will do that this pm.
Thankyou Wristpin,  that does look like mine, is much clearer than what I have and should be helpful in making the connections.
