skookum
AEBI AM 70 walk behind tractor
Just some pics - had this unit for some time now.
AEBI AM 70 walk behind tractor.
MAG 1035 - 8 hp - 4-stroke side valve - 350 ccm -  gasoline engine - purrs like a Swiss watch.
3 speed forward - reverse - differential lock - homemade front pto to norm 1 3/8 shaft
Custom made trailer hitch
more pics - handle bar adjustment refurbished
more pics - home made front pto adapter - shaft is 1 3/8th inch 6 spline - pulley is twin 13mm with internal 1 3/8 " norm hub
Edited by skookum
here the same unit in front of a sand spreader - a Danish sander with wheel driven dispenser shaft - dispenser rate adjustable by moving trough up/down from shaft by lever with lock positions
Dampened (adjustable) seat mount for added comfort - fitting pillow not shown
Edited by skookum
The AEBI AM 70 walk-behind tractor is an impressive piece of machinery that skillfully blends power and maneuverability, catering to the demands of efficient farming and landscaping tasks. With its robust design and user-friendly controls, this tractor serves as a dependable companion across a spectrum of agricultural applications. Whether you're nurturing a garden or overseeing a larger field, the AEBI AM 70 distinguishes itself as a versatile and trustworthy option, boasting Swiss precision and engineering excellence. Don't forget to explore the added versatility with the Boom & Bucket attachments. Thanks for considering this exceptional tool!
