Roadrunner123! 0 #1 Posted September 26, 2023 My O&S engine that was given to me was in storage for year. The gas smelled like kerosene and fuel lines were clogged. The fuel lines above the gas tank can be replaced but any thoughts on get the gas to flow through the line in the tank? thanks Share this post Link to post Share on other sites
Wallfish 718 #2 Posted September 26, 2023 Post some pics of the tank Carb cleaner, Brake clean Lacquer thinner etc soaking in the bottom of the tank as it could just be the screen filter is clogged from the old gas gum. Swish around every once it a while. Small wire into the tube if that's clogged too but don't bury it as there is a very delicate screen filter on the end. If you can get any flow then I use a bulb type thingy to force wash the cleaner back and forth through it until it clears out. https://www.ebay.com/itm/275523737691?var=0&mkevt=1&mkcid=1&mkrid=711-53200-19255-0&campid=5338590836&toolid=10044&customid=7c4ac16ac1301d9eea8ea4785ac465eb 1 Fishnuts2 reacted to this Share this post Link to post Share on other sites
Fishnuts2 22 #3 Posted September 28, 2023 I had the same thing happen, and used a fine wire and WD40 over a period of time to loosen the varnish in the tank line. Like mentioned before, the small screen is very delicate! Share this post Link to post Share on other sites
