tvenetis 1 #1 Posted October 12, 2025 I am trying to wind the recoil spring using vise grips and a vise but not so easy. I was wondering how other people wind the spring? After I wind it I hold it with vise grips and try to drop it in and the vise grips slips and it unwinds so I have to start all over again. Share this post Link to post Share on other sites
Wallfish 718 #2 Posted October 13, 2025 35 minutes ago, tvenetis said: I am trying to wind the recoil spring using vise grips and a vise but not so easy. I was wondering how other people wind the spring? After I wind it I hold it with vise grips and try to drop it in and the vise grips slips and it unwinds so I have to start all over again. I just use my fingers. Wind a bunch of wraps then pull on it so it tightens up the coil then pinch it tight again and repeat as many times as it takes. The factory new spring retainer is a piece of steel shaped like a C which keeps it tight in a package and makes then easy to install. You can make one out of a 1/8" sliver of 2 inch pipe. I think even PVC pipe would work. Wind the spring by hand, then let it uncoil into the C shaped retainer. That way it can easily be placed into the recoil housing. Then the retainer is removed while holding the spring down in the housing with your thumb. Let it uncoil slowly in the housing until it's tight 1 tvenetis reacted to this Share this post Link to post Share on other sites
Wallfish 718 #4 Posted October 14, 2025 Here's the recoil rebuild tutorial which might be helpful. Share this post Link to post Share on other sites
tvenetis 1 #5 Posted October 14, 2025 Before I tried to wind up the spring using a vise I was winding it up like you said but the end of the spring gets too hard to hold in my fingers. Share this post Link to post Share on other sites
